Wire question on turn signal running lights
jsaul53
Post by jsaul53 »
I am trying to discern what these three wires are. I know black is ground, green turn signal? blue with red stripe? running light??
I am trying to find a source for switched power and this was suggested elsewhere. But before I tap one wanted to make sure what was what.
http://i259.photobucket.com/albums/hh30 ... G_1031.jpg
Thanks
x 1428
x 3476
Re: Wire question on turn signal running lights
Use the power to the outlet in the glove box. It is easier to get to. I don't use it for anything else as I power my tank bag from the battery tender plug. Keep in mind I am suggesting using it to drive a relay like on an FZ-1 Fuseblock not for a power feed. (I will bet that is what you are looking for too)
jsaul53 wrote:I am trying to discern what these three wires are. I know black is ground, green turn signal? blue with red stripe? running light??
Thanks
If you choose to go this route, the Green wire is the right turn signal, the Blue/Red wire is the tail lights and license plate light.
The glove box wire (Brown/Black) or one of the front marker lights (Blue/Red, both R & L sides) are also popular places to pick up switched ignition voltage to turn on a relay but not power accessories.
(If something goes wrong, which circuit would you prefer to lose, in the rain, in the cold, at midnight? ;) )
jsaul53
Post by jsaul53 »
Thanks
