FJR1300 Valve Adjustment - Parts List
- clocklaw
- Swag Master
- x 469
- x 254
Ok, I am embarking on the FJR1300 Valve Adjustment in a few weeks on my 2005 and a friends 2006 and I wanted to get a list together of things I will need to make this happen smoothly. When I did my 2003, I needed to replace the cam chain tensioner while I was in there, is that necessary on the 2005?
For the 2005 I think I will need:
Timing Chain Cover Gasket
Coolant Tube o-rings
possibly a valve cover gasket
coolant
maybe a Cam Chain Tensioner?
Plugs (thanks HogTied)
How about for the 2006:
possible valve cover gasket
coolant
CCT???
coolant
coolant
CCT???
- FJRModel: Super Tenere
Re: FJR1300 Valve Adjustment - Parts List
Do you have a shim kit or are you just going to order the sizes you need after you take your measurements? A shim kit is about $100, but it can save you a week of dowtime.
- clocklaw
- Swag Master
- x 469
- x 254
I don't expect to need them....I will order what I need if there is a problem. Both bikes are first check (mine is about 25,000 miles and Howard's is <30,000)
- Name Etc.
Ive need nothing but the coolant tube o rings on my 07. Third check coming in the next month... Good luck. Oh, coolant, I used new coolant.
ThisMotorCycleLife.net
- hogtied
- FJRModel: 0351
- x 2
I've just done my 95,000 full service on my 03 , engine was as clean as the day it was put together , valves were still in spec , cam chain still in perfect tolerance , changed uridium plugs , synked carbies , filter , all fluids , coolant , brakes , i must say these bikes are pure engineering , very hard to fault , alas this is Australia and we do not have the cold winters as yours , and the salt degredation , due to your icing roads , would be interesting to compare spec wear due to two different climates
Sent from my GT-I9100T using Tapatalk 2
- Queensland Ken
- FJRModel: 2014 AE
- x 2
And a can of black spray paint for when you clean up the the coolant pipes.
2014 AE Black
13 Stilvio NTX
2007 GSX1400
2002 TL1000R
13 Stilvio NTX
2007 GSX1400
2002 TL1000R
- x 2356
- x 14502
I ordered a valve cover gasket. It's one of those things that if you have it, you won't need it...
So if you get into it, and you end up tearing one, I have one I can overnight to you.
I did the valve check - which is what you're embarking on here - on Vader 1.0 at 28k miles. Everything was on the good side of good, the insides were spotless. That motor was mine from day one, it was taken care of, and run hard. Yamaha engineers got it right...
- clocklaw
- Swag Master
- x 469
- x 254
I have a good local dealer and he keeps all of that stuff in stock...so worse case is that I might have to wait a day. Also, the service manager lives in town so he'll even bring the parts home with him and drop them off.extrememarine wrote:I ordered a valve cover gasket. It's one of those things that if you have it, you won't need it...
Does the Gen II need to coolant tube o-rings also?
Also, I will probably get a set of the WynPro block off plates to install while I am in there.
Finally, what's the black spray paint for Ken???
- Queensland Ken
- FJRModel: 2014 AE
- x 2
You'll be surprised to see how much corrosion there is when you remove the coolant pipes from the cam cover.Finally, what's the black spray paint for Ken???
Done a few valve checks on mine and other FJR's and they all seem to gather debris and water down the recess.
When I take the pipes off I clean them up and paint them, ready to install latter on.
The other trick I do is to clean up then install / silastic the gasket into the cam cover when I remove it.
Much better when it comes to installing the cover.
It's a real bugger trying to keep the gasket in place and not to damage it when fitting the cover.
Cheers
2014 AE Black
13 Stilvio NTX
2007 GSX1400
2002 TL1000R
13 Stilvio NTX
2007 GSX1400
2002 TL1000R
- clocklaw
- Swag Master
- x 469
- x 254
Gotcha, when I did my '03 I just cleaned them up really nice and reinstalled, I didn't paint anything.Queensland Ken wrote:You'll be surprised to see how much corrosion there is when you remove the coolant pipes from the cam cover.Finally, what's the black spray paint for Ken???
- clocklaw
- Swag Master
- x 469
- x 254
Ok, here is an interesting question: has ANYONE seen a FJR out of spec at the first Valve Check?
- Queensland Ken
- FJRModel: 2014 AE
- x 2
Nope, I'd leave it to at least 80+ K kms. Or if there are any obvious noises.
2014 AE Black
13 Stilvio NTX
2007 GSX1400
2002 TL1000R
13 Stilvio NTX
2007 GSX1400
2002 TL1000R
