Valve Check Timing
- usaffjr
- FJRModel: 2006 FJR
Valve Check Timing
With my bike not running right, the coolant leak at the thermostat housing, and 24k on the clock, I'm wondering if it would just be wise to let the dealer so the repairs since it's all tied together. Really, the additional required labor to replace the tstat is nothing if you're doing a valve clearance check. Already have to drain the coolant. Replacing the plugs only take a few minutes since the head is being pulled.
I went through the steps to adjust the valves and just don't feel comfortable doing that myself, so that's not an option. I know some people think it's not even required..
Thoughts?
Thoughts?
- clocklaw
- Swag Master
- x 469
- x 254
Re: Valve Check Timing
Why is the head being pulled?
- usaffjr
Sorry, valve cover. That's what happens when I post too early in the morning.
- usaffjr
Called the dealership and they said around $500 for everything. Includes plugs, tstat replacement, valve check, throttle body sync, oil change... think I'm going to give that a try.
- clocklaw
- Swag Master
- x 469
- x 254
If you don't feel comfortable doing it yourself, that seems like a reasonable budget. Make sure that includes a complete coolant change and not just a draw down and top off.
- Name Etc.
Just out of curiosity related to this post. Has anyone found an FJR out of spec at the 26k mark? I've done three checks and 94,000 on the bike. At the third check is was still in speck tight side but still inside tolerance. Will I do the 105,000 check? I don't know.
ThisMotorCycleLife.net
- Name Etc.
- Bust
- x 6167
- x 1767
Hard to call name.. We've done several over the years here.
One or two needed love, but still, you just never know.
- usaffjr
With the problems I've been having the last few weeks, it's with a look.
Also, it includes new coolant. Bad news is I just paid to have a flush and fill done in May. That was in Vegas, though...
- x 3430
- x 12685
Chances are at 24k, no shim changes are needed, but have the dealership document the clearances for you. You might be able to fix a coolant leak by tightening a hose clamp unless its leaking around the housing....
The budget number sounds about right........
- usaffjr
- FeeJeR Fred
- FJRModel: 2014 FJR1300ES
- x 5
- x 20
Answering the original question:
According to a poll taken on the other FJR Forum, 21 of the 153 who responded (~14%) said that their 1st valve check required adjustment. 7 of those were done at the dealership and 14 were DIY guys.
- Fred W
- usaffjr
- x 3980
- x 6902
Hey! It's alive!raYzerman wrote:The budget number sounds about right........
- x 4548
- x 6197
Mine 09 needed a valve adj at 36k. I will leave the adjustment to the dealer but I don't mind doing the check. If you or the dealer do it depends on your wrenching skill and willingness to part with a few bucks.
