I bought the seated heat option with my Laam custom seat and I am trying to decide where to put the on/off toggle switch. I have searched the web and haven't found where to install and I do not want to cut the seat to put it where I see other seats. I have seen where some folks have used a hand grips heat troller instead. Anyone with experience with this too include pictures?? This is what a rainy weekend does to the farkling spirit.
Thanks
Heated seat option Laam
- FJRModel: 2008
- HotRodZilla
- FJRModel: 07 FJR-A
- x 13186
- x 6371
- x 12959
Re: Heated seat option Laam
Just a thought from the heated Corbin I had once...... it was a low profile toggle switch mounted on the side of the seat itself, get a rectangular Off-Low-High dual pole switch with bezel, cut it in just behind your left cheek down on the side. You'll need (or should have got with the Laam) a resistor for the low heat circuit which you can hide under the seat on the back side..... similar to the ones that come with heated grip sets (I have a couple of spares somewhere, I'll look up the values, get them at RadioShack). OR, mount the switch somewhere else (side of the tank trim piece?), it's only wire, but put a quick disconnect connector under the seat for when you want to remove the seat. If you got a tall lever type switch, I'd ditch that for a lower profile one that can handle 10+ amps. You could also double relay it so you can use a small dual pole switch that might be more "fitting" and less ugly.
Variable controller is just pure luxury, not needed IMHO.
- silverback
- x 1250
If I had that sort of money for such luxury....
I'd put a microswitch in the left hand control housing that runs a relay. Then, if I were super spoiled, that microswitch would run a relay that would select between high and low heat. The on and off could be switched else where or with another relay through a DPDT microswitch with an off position.
Just sayin.
Just sayin.
- bluesdog
- FJRModel: 2011
Just install an adjustable thermocouple under the seat. Hook that to a relay, and the heat circuit will automagically turn on when yer butt gets chilly.
- silverback
- x 1250
That's a bad idea. Every time you fart, it'd back feed through the thermocouple and blow a fuse! LOL!bluesdog wrote:Just install an adjustable thermocouple under the seat. Hook that to a relay, and the heat circuit will automagically turn on when yer butt gets chilly.
