Go Cruise Throttle Lock
x 5052
x 6790
I learned about this $20 throttle lock from a fellow FJR rider. It is called Go Cruise. It uses the break lever as a stop; just open the throttle and push it to the brake lever with one finger. Just do a web search to find it at your favorite store.
I bought one and for $20 bucks it works great so far. Get the 7/8 size not the 1 inch size. Don't ask me how I know. The size refers to the handlebar not the hand grip diameter.
I have used it for one day so don't have much experience with it (hence the so far qualifier in the last paragraph).
I got it for those long rides on the slab, short breaks or tension relief.
Tech junk:
1) It slips when you want to roll off the throttle. Easy.
2) Like other throttle locks it won't hold speed on up or down hill sections.
blrfjr
x 32
x 159
Re: Go Cruise Throttle Lock
Post by blrfjr »
I just bought one of these for my dualsport. Since the d/s has short grips, I like that I can easily remove it when I dont need it and put it in my tank bag or pocket.
Bryan
cognosticator
FJRModel: 2013
x 8
Post by cognosticator »
I got one of those, it works great and the price is right
Jerry Holland
2013 FJR
"Man, you were haulin ass the other day when I passed you"
usaffjr
FJRModel: 2006 FJR
Post by usaffjr »
I used mine on my last road trip. Worth every dollar.
Mattthehoople
Post by Mattthehoople »
Yeah, I have the aluminum version. It has a tension screw that is easy enough to adjust on the fly.
Its certainly not cruise control, but it works for me.
spklbuk
x 3352
x 6845
Post by spklbuk »
Works well on the Tenere for some hand R & R. Use it a lot.
Montani Semper Liberi
