- x 9737
- x 4127
So I noticed on the 2013, when I shift from 2nd to 3rd, sometimes the bike doesn't end up in 3rd gear. I get stuck in 2nd unless I point my toe down and re-shift into 3rd. Obviously the toe of my boot is a little tall and is partially engaging the shift lever upwards before I shift. At that point, I'm unable to easily shift into the next gear until I point my toe down again and re-shift.
So out comes the service manual. How do you adjust the shift lever a little higher? Easy peasy. I loosened the lock nuts on the barrel of the shift rod and spun that baby until the shift lever started rising, There are to little marks on the metal near the shift lever. The final adjustment has to be between those marks. As I looked, my shift lever was adjusted near the bottom notch. I raised it to near the top notch and tightened the lock nuts back up on the barrel.
I just came back from a test ride, I never missed one shift. These kind of results make me very happy.
Hppants, Cav47, danh600 and 2 others loved this
- x 6289
- x 10360
I don't bother with the lever, just push the button.
Cav47, mcatrophy, wheatonFJR and 1 others loved this
- x 2388
- x 14702
Staged tire changing equipment - New (crappy) RS3's going on for SEO. Wheaton and his boat anchor(s) will be there, so I was almost tempted to leave the 7k mile set on but then decided I'd rather not roll the "IronPony Service Deptment on a Sunday" dice this trip...
Bike needs a bath first thought - the rain / sleet / snow mix left layer of filth that would give D-Eagle a stroke...
Spininprop, BikerGeek, Cav47 and 4 others loved this
- x 9737
- x 4127
Been there done that for many years.
mcatrophy and gixxerjasen loved this
- x 4470
- x 12622
Don't worry, you'll get a big boy bike one day
Cav47, FJRPittsburgh, and wheatonFJR loved this
I washed mine Sunday, after the slightly-overdue 25,000 mile oil/filter/FD fluid change.
I have a set of PR4GT’s in the garage, and I’m probably a month from finishing my RS3 rear tire. After gentle ridicule from Wayne on my disdain for the RS3 in the cool and wet, I’m considering trying another.
Two rear flats in a month and a slide out with the new rs3, (because I didn’t do the adult thing and scuff it up before sending it), didn’t help my picky superstitious tire predilection. Lol.
- PhilJet09
- FJRModel: 2009 FJR1300A
- x 3154
- x 1342
Rode home last night in the rain…opposed to rain and snow on the way to work the day before. Today, I left it in the garage and took the wife’s car to my FAA Physical. I guess I’m getting old. Eye test confirms it. How did that happen?
D-Eagle, FJRPittsburgh, and wheatonFJR loved this
Calm is a skill.
Calm is a skill.
- x 48476
- x 20518
My recommendation? Leave the 7k set on...you're due for an Iron Pony visit. Wash it? After Geek washes his...Whoop, there it is! Whoop, there it is...extrememarine wrote: ↑Wed Apr 26, 2023 7:37 pm Staged tire changing equipment - New (crappy) RS3's going on for SEO. Wheaton and his boat anchor(s) will be there, so I was almost tempted to leave the 7k mile set on but then decided I'd rather not roll the "IronPony Service Deptment on a Sunday" dice this trip...
PhilJet09 loved this
- x 48476
- x 20518
You didn't die. Consider yourself fortunate.
- PhilJet09
- x 3154
- x 1342
Excellent point! We should all remember that every day is a gift.
Bugnatr and Hppants loved this
Calm is a skill.
Calm is a skill.
- x 4528
- x 2297
I find a weak shift from 1 to 2 results in a missed shift to 3.FJRPittsburgh wrote: ↑Wed Apr 26, 2023 7:17 pm So I noticed on the 2013, when I shift from 2nd to 3rd, sometimes the bike doesn't end up in 3rd gear. I get stuck in 2nd unless I point my toe down and re-shift into 3rd. Obviously the toe of my boot is a little tall and is partially engaging the shift lever upwards before I shift. At that point, I'm unable to easily shift into the next gear until I point my toe down again and re-shift.
- x 9737
- x 4127
That's not been my experience. Raising the shift lever was my fix. I need to do the same shift lever adjustment to my 900GT.N4HHE wrote: ↑Wed Apr 26, 2023 9:44 pmI find a weak shift from 1 to 2 results in a missed shift to 3.FJRPittsburgh wrote: ↑Wed Apr 26, 2023 7:17 pm So I noticed on the 2013, when I shift from 2nd to 3rd, sometimes the bike doesn't end up in 3rd gear. I get stuck in 2nd unless I point my toe down and re-shift into 3rd. Obviously the toe of my boot is a little tall and is partially engaging the shift lever upwards before I shift. At that point, I'm unable to easily shift into the next gear until I point my toe down again and re-shift.
- x 3528
- x 12983
The shifter adjustment should be where you need it, doesn't have to be between the two lines... really big boots might have you moving the shift arm one notch on the splines if you run out of adjustment.
One would be very wise to make a positive shift 1-2 to get it fully engaged. You want to minimize the wear on the 2nd gear dogs. One technique is to slightly preload the shifter just before you shift.
Also some FJR guys have replaced the shift arm with one off a certain year R1. It has a shorter throw.
- Red
- FJRModel: 2008 FJR1300ABX
- x 225
- x 1218
Riders,FJRPittsburgh wrote: ↑Wed Apr 26, 2023 7:17 pmSo I noticed on the 2013, when I shift from 2nd to 3rd, sometimes the bike doesn't end up in 3rd gear. I get stuck in 2nd unless I point my toe down and re-shift into 3rd. Obviously the toe of my boot is a little tall and is partially engaging the shift lever upwards before I shift. At that point, I'm unable to easily shift into the next gear until I point my toe down again and re-shift.
Several bikes in my past have had heel-and-toe shifters. It took one ride for me to like that idea, but it did seem odd for a bit. Here is a DIY bolt-on (no drilling the bike) heel-and-toe shifter, if anybody would like it, too. Good mod, for damaged legs.
https://www.fjrowners.com/threads/heel- ... st-1313082
The R1 shifter linkage has a shorter throw arm, and that is a good deal also.
- x 15884
- x 15035
Installed the Givi Rack
Swapped the red cover on my Givi 46 top box with the black one. It looks pretty dog gone good.
Ordered:
- speedbleeders
- saddle bag reflective decals
- Seat bracket grommets (somehow they were missing)
- 90 degree valve stems
- tank protector decal
- Givi Tank Bag fitting
- Touch up Paint pen
I need to re-make my accessory wiring harness. The fuze block will be mounted under the pillion seat, as opposed to the rider's seat as it was on the '14. Therefore, I'm about 18" short on wiring. I ordered all of the electrical materials.
I got a list of "to dos" mechanically for the 2021. Over the next week, I'll be checking those off, one by one.
Retirement is fun!
Ordered:
- speedbleeders
Retirement is fun!
Cav47, FJRPittsburgh, and N4HHE loved this
- x 48476
- x 20518
Pointed it towards the garage door. Got some packing completed. We'll see if Lucky is ready for 500+ miles of curvy Flat, straight, and boring roads on Thursday.
El Toro Joe, Spininprop, FJRPittsburgh and 1 others loved this
- x 2388
- x 14702
Prepped for SEO...
El Toro Joe, Bugnatr, FJRPittsburgh and 1 others loved this
- x 6289
- x 10360
Moved it over into the space vacated yesterday by the gixxus. Got room in the garage again to work on stuff.
- x 2446
- x 3284
Jeff,FJRPittsburgh wrote: ↑Wed Apr 26, 2023 7:17 pm So I noticed on the 2013, when I shift from 2nd to 3rd, sometimes the bike doesn't end up in 3rd gear. I get stuck in 2nd unless I point my toe down and re-shift into 3rd. Obviously the toe of my boot is a little tall and is partially engaging the shift lever upwards before I shift. At that point, I'm unable to easily shift into the next gear until I point my toe down again and re-shift.
You may want to look into getting the R1 shift arm. It is shorter and decreases the throw of the shifter. I'm sure a search would turn up the part number.
- x 15884
- x 15035
Is the herd thinning out?gixxerjasen wrote: ↑Sun Apr 30, 2023 8:34 pm Moved it over into the space vacated yesterday by the gixxus. Got room in the garage again to work on stuff.
