Vintage Project - Yamaha DS7 - 250
- x 12959
Re: Vintage Project - RD250
Ah yes, but to do it right you have to put a Triumph seal in an ES first, then replace with the correct ES seal..... in your case, have the RD seals ready but also a set for the DRZ... we'll get it right eventually.
- x 4054
- x 6947
Black shoe polish on the outside of the tars. That theirs a tip from Burt Munro. How could it be bad advice?!extrememarine wrote: ↑Thu Oct 25, 2018 5:46 pm If Ray helps me put it back together, the fork seals will get flipped and end up right side up then.
I plan on running these tires - just going to add some gorilla tape to the inside to keep them together about 90...
wheatonFJR wrote: ↑Wed Oct 24, 2018 9:35 pm Looking good, cept mebbe that crack in your front tar...that you were replacing when the other stuff gets done.
I'm not sure, but from here it looks like the fork seals are installed upside down.
extrememarine loved this
- FJRModel: 2015 fjr
- x 11
- x 19
You are from West Virginia.....?
- x 2385
- x 14699
Progress update - 2/10/19.
No where to go but up from there...
Puc, CollingsBob, and wheatonFJR loved this
- x 48429
- x 20499
- FJRModel: 07 FJR1300
- x 169
- x 172
I guess you already know this, but this is not an RD it is a YDS7.
- x 2385
- x 14699
My historical education on this is still in it's infancy. Now I realize why there was some confusion when I said earlier there were not reeds - RD250 in '73 had reeds, the DS7 (250) had piston port induction. This little snipet below says this bike put out 30hp at 7500rpm - holy cow - that's like two complete DR650's!!
The Yamaha DS7 motorcycle was made in 1972 for one year. It was a 250cc twin two-stroke that made 30 hp @ 7,500 rpm. Top speed was 93 mph. 12v battery ignition. five-speed gearbox. 1/4 mile in 14.8 seconds.
The DS7 was the initial forerunner of the Yamaha RD series of motorcycles started in 1973. The major difference between the 250 cc DS7 and 350 cc R5 of 1972 and the 1973 RD250 and RD350 was that the DS7 and R5 utilized piston-port induction, whereas the RDs were introduced with reed valve induction. The 250 was "oil injected" meaning that although the 250 was a 2 stroke or (2 cycle engine) there was no need to premix the gas and oil. The gas tank only contained gas but the oil was injected from an oil tank beneath the seat.
From wiki link:philharmonic wrote: ↑Mon Feb 11, 2019 9:56 am I guess you already know this, but this not an RD it is a YDS7.
Puc and Bust loved this
- Bust
- x 6167
- x 1767
Re: Vintage Project - Yamaha DS7 - 250
I have a 28 horse Kohler V twin on the shelf. I bet with all the brain power on tech day we could mount it in there.
Now how to couple it with a baker 6 speed.
Puc loved this
- x 2385
- x 14699
The fact that the stock motor is advertised with 30hp is nutz - I'll bet that Kohler weights 40lbs more than the 2 stroke!!
Baker 6speed - hmmm....
- mi_pjk
- FJRModel: 2014 A
- x 380
- x 207
Is that what you call one of those : "Oxy-Morons" ?
Puc, wheatonFJR, Hppants and 1 others loved this
Assfaulticus Slabtasticleese
'14A, '10 XCW 450, Sportsman 600 (plow)
- x 12959
Dayum.... the Kohler V-Twin in my tractor is only 23 horse...... hmmm, trailer or truck..... hmmmm.
- MindWebs
- FJRModel: 2012 FJR, Current.
- x 23
- x 30
93mph.. that's it?
My 75 Kawy s1 250 is good for 115.
But a little port'n polish job helps ALOT.
So consider it, porting and polishing should help it breath another 10 HP. Maybe? Maybe not that much...
At least it would accelerate faster
Because that 2 stroke smoking screamer needs faster power band hits, right?
Then you can honestly say some joker put a spare tire on the front of your uni-cycle.
(Factory rating for the kawy is around that 95mph range)
Puc loved this
2012 FJR, front and rear crash guards, highway pegs, throttle lock, driver backrest, 1" bar risers, pirelli angels normal spec.
I'm not sliding, It's rear wheel steering!
