veriest1
FJRModel: 2007 FJR, 02 1150GSA, 16 CB500X Rally Raid, 02 XR650R, 08 950 Super Enduro
x 20
x 12
Post by veriest1 »
I got the cheap bar risers installed yesterday. Seems to have given me that little bit I needed to get comfortable with the seat in the tall position.
x 6289
x 10360
FJRoss wrote: Mon Aug 16, 2021 9:01 am
bungie4 wrote: Mon Aug 16, 2021 8:55 am
wheatonFJR wrote: Sat Aug 14, 2021 5:04 pm like making sure I have a second pair of briefs for this NAFO trip.
Longer than 4 days huh.
Rightside out
Inside out
Frontwards
Backwards
Check - good for four days
It's called....Recycling.
https://www.youtube.com/watch?v=bGYkNuZCnpY
x 6289
x 10360
Red wrote: Sun Aug 15, 2021 10:55 pm
gixxerjasen wrote: Sun Aug 15, 2021 6:31 pmThis weekend:
Prepped the new upper Triple by pulling the old ignition studs, cleaned it up, and installed my ignition into it with regular cap head bolts. I bought the safety nuts but after drilling and pulling two sets (one from the new triple and getting my ignition off the old one) I decided to stick with something easy. After all, the thieves don't know I have it and it doesn't really deter them, and a 90K mile motorcycle won't bring them much cash anyways.
gixxerjasen,
Okay, I tend to expect the worst, at least in some cases. I would not use the OEM security screws either, but I would replace them with Allen heads. If they were not black headed screws, I would paint the heads black. Once installed, then fill the Allen recesses with black RTV. Anybody who looks will see OEM security screws, because that would be expected there. If you ever need to remove the screws, it's an easy swipe with a scalpel to clean out the RTV for maintenance. Amazon has scalpel-handle plus blade deals, for pocket change. The #11 scalpel blade is like the X-acto #11 blade, which would do the same job. You can buy a grundle of scalpel blades for the same price as a few X-acto blades.
Good point. I went out and looked and you have to look really hard and know what you are looking for to realize they aren't security bolts. Also, you'd first have to question that this particular bike doesn't have security bolts and care about it to get in there looking. I'll go with your plan though next time I'm digging around in there and have it apart. Until then, I'll just continue my current process of not washing it and leaving it uglier than any other bikes around so that would be thieves will rather target other bikes than touch my nasty mess. :D
Also, judging by thick layer of crap that was on the bottom of my triple, I doubt those bolts will remain silver for long on their own. :D
x 1404
x 677
Ok took a little shakedown ride about 60 or so miles to check to see if my sealmate treatment worked also was running with probably less than a quarter tank of gas and wow what a difference that makes. Well sealmate was unsuccessful so I gave it another shot bounced the front and seemed to stay dry so I have my fingers crossed. I'm hoping it works, I don't really feel like doing the forks right now. Means I would have to decide just do the seals or go whole hog bushings too? Attempt it myself or get ripped off from the Stealer. Of course either way would do the Spring upgrade but then I would need to do the rear shock. The Domino effect. :lol:
veriest1 and wheatonFJR loved this
x 6289
x 10360
After years of using a homemade seal mate, I borrowed one of these (Probably not the right size) from a friend once for cleaning forks. It's freaking amazing. I still need to pick one up for me.
https://www.amazon.com/HYKJ-Motorcycle- ... 132&sr=8-6
veriest1 loved this
x 2631
x 2124
Since I decided to take the FJR on the Trifecta it's maintenance time. Oil change plus a new filter and bled the less than stellar rear brake circuit. Few bubbles from RH front, fluid from rear caliper clean. Leaving for NAFO next weekend...can't wait!
Niehart, fontanaman, El Toro Joe and 2 others loved this
x 1404
x 677
gixxerjasen wrote: Mon Aug 16, 2021 5:26 pm After year of using a homemade seal mate, I borrowed one of these (Probably not the right size) from a friend once for cleaning forks. It's freaking amazing. I still need to pick one up for me.
Wow that looks great. I'll have to pick one up. :)
gixxerjasen loved this
John d
FJRModel: 2008A
x 929
x 647
Post by John d »
Rode 1100 miles over the weekend (3 days). This with a new Bridgestone T32GT front tire and a T32GT rear that already had 2000 miles on it. Normally a new set of tires behave really well. I could not believe how well these tires handled - very impressed. I felt like I had just jumped on a bicycle. Tar snakes were not too noticeable.
The new front T32 replaced a Pirelli Angel GTII that got pointy and handled like a truck, and that also felt unhinged on tar snakes.
Long term performance, I don't know yet, obviously.
veriest1 and El Toro Joe loved this
x 4529
x 2297
Got out for a nice ride today. Enjoyed the relatively low temperature and humidity. Filled truck with gas yesterday expecting Afghanistan to be an excuse to raise prices 25¢ but they fell 5¢ this morning.
x 4646
Today, I watched a friend perpetrate a helicoil to repair my stripped lower brake caliper bolt. Went well.
Together, we checked wheels for damage. None found. I have had a busyness, a fluttering bounciness, that reminds me of my last pickup truck when it was ready for new shocks. Doesn’t get better or worse at speed. No notable vibration. It’s like it’s hunting, rarely settles down.
Been this way for a couple of weeks. Happens regardless of suspension setting. Front and rear suspension feels like it’s working fine when I work it in the garage. Rear tire is fairly new. Front is plenty worn. No idea so far. I’m going to replace the front tomorrow and see if it helps. Baffled.
x 3119
x 3421
Mounted 2 new Pirelli Angel GT tires, lubed drive shaft splines and took a short test ride. Had to work some getting these tires on. Many pairs of Michelin PR2S had me spoiled for ease of installation.
x 6259
x 10422
Got mine back from the shop. All maintenance done. Ready for road trips this fall.
Dreaming of EOM, Barber Vintage Fest and SFO.
But first I have to sell my house and move.
FJR might sit in the trailer for a few more weeks.
extrememarine, Hppants, and bill lumberg loved this
x 4646
I’ve been by barber, off that exit, scores of times. Never been to barber itself. And always wanted to go to vintage fest, ever since my bmw mechanic couldn’t fit me in for one of my many breakdowns because he was showing bikes at vintage fest. Ping me and I’ll meet you there.
Replaced my front tire today. Didn’t fix the bouncehaus. I think I may have an out of round rear tire. Ok just going to ride it out, figuratively and literally, until
It’s time to replace it.
danh600 wrote: Sat Aug 21, 2021 9:36 pm Got mine back from the shop. All maintenance done. Ready for road trips this fall.
danh600 loved this
x 6289
x 10360
bill lumberg wrote: Sun Aug 22, 2021 6:35 am I’ve been by barber, off that exit, scores of times. Never been to barber itself. And always wanted to go to vintage fest, ever since my bmw mechanic couldn’t fit me in for one of my many breakdowns because he was showing bikes at vintage fest. Ping me and I’ll meet you there.
I love telling this story.
NTXFJR and I rode to SFO and planned to stop by Barber on our way. In the parking lot, stowing our gear NTXFJR says "I hear you can spend hours in this place, I figure 45 minutes and I'll be on my way, stay as long as you like though." Before you go in, before you even buy your ticket, there's a nice 3x3 vertical display of bikes that NTXFJR spent 20 of his allotted 45 minutes drooling over. We did spend hours in there, what an amazing place for a motorcycle fan.
raYzerman, N4HHE, and bungie4 loved this
bill lumberg wrote: Sun Aug 22, 2021 6:35 amReplaced my front tire today. Didn’t fix the bouncehaus. I think I may have an out of round rear tire. Ok just going to ride it out, figuratively and literally, until It’s time to replace it.
Bill.
Put the bike on the centerstand. Start the engine, and select first gear. With the rear wheel turning, brace a china-marking crayon against the ground and hold the writing end of the crayon steady near the rear tire. Move the marker closer to the tire slowly, until it begins to touch the rotating tire tread. If the crayon marks all along the tread, the tire has no high spot. If only one part of the tire gets marked, the mark will be on the high spot.
If you have a small jack, you can lay a screwdriver across the jack and hold the tip steady, near the rim. With the wheel rotating, you will see if the rim is running straight and true. HTH.
Uncle Hud, Cav47, wheatonFJR and 1 others loved this
deleted, duplicate post.
x 4646
I did that yesterday. No sign of trouble. Pretty much nothing left to try, that I can think of, except to pull it and rebalance it to see if that helps. I don’t know that the rear tire is the cause, but I noticed the fluttering not too long after I mounted it.
Red wrote: Sun Aug 22, 2021 12:32 pm
Bill.
x 48487
x 20528
Rode. Had breakfast. Ate lunch.
Encountered assholes in a Toyota in AR at 16 and 23. Thought I was going to need to defend myself for a few minutes. Gonna take a CC course and purchase a different self defense weapon when I get home. Could have been bad.
Did not take the joy out of the riding and scenery seen today. Tomorrow-OKLAHOMA!
Praying for lots of rain cells tomorrow.
x 5085
x 6816
Put gas in it. Going to NAFO on Tuesday.
x 6259
x 10422
wheatonFJR wrote: Sun Aug 22, 2021 6:25 pm Rode. Had breakfast. Ate lunch.
I carry. However I think the FJR will get you out of a situation better. Plus no lasting legal issues.
