- FastPappy
- FJRModel: 2009 AE
- x 1373
- x 655
Had a nice little RTE with my brother in law (Harley Guy) about 155 miles. Went to the same place we went to last time (no gravel road this time). So we pull up and he is off the bike and headed for the door while I was futzing around with something before you know it he's back and laughing said they're not even open. So we head back to a little diner we passed on the way. I had a cheeseburger with jalapenos and fries. When I got home and parked the bike I see some stains on the ground I hadn't noticed before so I check the forks and sure enough a bit of oil weeping. So out comes my trusty homemade seal mate. I do the deal and clean everything, give a few good pushes on the bars and repeat just incase. Check again and seems to be ok. I'll have to wait till the my next ride to see if everything is okay.
- x 930
- x 2697
I did that 3-4 times over the past year. Never got to the point where it dripped on the garage floor but forks and brake calipers were frequently wet with fork oil. Seal-mate worked for a while but these seals probably had 85,000 miles on them. Finally bit the bullet and did new seals and bushings this past spring. (Once I cleaned them up, the brakes worked way better!) Probably should have sent the innards back to Traxxion (AK20) but would have been without for a couple weeks. Next time...FastPappy wrote: ↑Mon Aug 02, 2021 5:52 pm ... When I got home and parked the bike I see some stains on the ground I hadn't noticed before so I check the forks and sure enough a bit of oil weeping. So out comes my trusty homemade seal mate. I do the deal and clean everything, give a few good pushes on the bars and repeat just incase. Check again and seems to be ok.![]()
- x 486
- x 1329
Steering bearing re-torque today. A previous owner had installed tapered bearings but didn't keep it long enough after to warrant doing it.
- x 930
- x 2697
What torque spec did you use? No issues with my OEM bearings but if they had to be replaced, I would probably go with the tapered. (Never replaced them on the '07 sold with 185,000 miles - still not notchy, loose or rough)
- x 4409
- x 2264
I find the tapered bearings are relatively insensitive to preload. Just take out the slack and a bit more. Yamaha’s procedure us quite satisfactory.
- x 486
- x 1329
I found on my '07 with the wobble, tapered bearings seem to work better with a touch higher torque than the OE ones do. OE is 37/13. I torqued the tapered ones to 45/20.
Also, since I had to remove the top plate, I raised the tank while the handle bars were still out of the way and replaced the spark plugs & throttle body rubber caps.
- x 4139
- x 4636
Installed another reflector below the license plate. Put new real-time reflectives on the back of the bags, incorporating a reflective American flag on one side
Inspected the rear tire, and decided it can wait until Saturday to be replaced.
Blueridgerider, N4HHE, wheatonFJR and 1 others loved this
- x 2364
- x 14540
Mind sharing a picture?
wheatonFJR and danh600 loved this
- x 4009
- x 6913
I politely told a prospective buyer that 82Km is not a lot of km's and that his offer of $3500 would be better spent obtaining an education, or, medical treatment to correct his obvious cognitive shortcomings.
fontanaman, BikerGeek, Spininprop and 7 others loved this
- x 2364
- x 14540
Seems like a solid low ball approach strategy...
- x 4139
- x 4636
I just checked with my doctor. It’s been around 38,000 miles since my valve check. Intakes ranged from .18-.20, exhaust from .20-.23. Trying to decide if I’m having it done again this fall, or not. Probably will.
BikerGeek loved this
- x 4139
- x 4636
Blueridgerider, BikerGeek, extrememarine and 1 others loved this
- x 4409
- x 2264
Have sadly noticed how hard it is to buy good American flag decals. I have a small one on my rear fender which needs to be replaced. Fortunately I have extra from 5 years ago but you can’t find a decent flag decal at formerly American Walmart, now the local CCP bureau.bill lumberg wrote: ↑Tue Aug 03, 2021 5:13 pm Installed another reflector below the license plate. Put new real-time reflectives on the back of the bags, incorporating a reflective American flag on one side
- BikerGeek
- x 5390
- x 4717
C'mon up to Tech Day!bill lumberg wrote: ↑Wed Aug 04, 2021 9:54 am I just checked with my doctor. It’s been around 38,000 miles since my valve check. Intakes ranged from .18-.20, exhaust from .20-.23. Trying to decide if I’m having it done again this fall, or not. Probably will.
- x 3444
- x 12741
Next year is fine since they all look decent.... besides, may not be able to make this one and sure would like the opportunity to break sumthin' on yer scoot. No wait, you're going to Geek's, he's good at it.BikerGeek wrote: ↑Thu Aug 05, 2021 1:39 pmC'mon up to Tech Day!bill lumberg wrote: ↑Wed Aug 04, 2021 9:54 am I just checked with my doctor. It’s been around 38,000 miles since my valve check. Intakes ranged from .18-.20, exhaust from .20-.23. Trying to decide if I’m having it done again this fall, or not. Probably will.
- Boston
- FJRModel: 2005 FJR1300 2001 Roadstar
- x 122
- x 184
ordered tires for that new bike feel. Going to EOM and don't want any problems or worries.
extrememarine loved this
IBA# 76760
- x 47483
- x 20148
Bribing jwilly with new tires is a good start I will admit, but what about Bob? I’m not sure your worries are over.
- x 958
- x 813
Picked up the last gasket for my valve check this sat. Looking forward to EOM.
- x 4139
- x 4636
Swapped on a new PR4GT rear. When putting everything back together, the lower brake caliper bolt pulled the threads, all of them, out of the caliper mount, as pretty as you please. There was never any resistance at all.
Seems stable. I’ll have to keep an eye on it until
I can get a replacement mount, and a couple of bolts for good measure.
- x 2364
- x 14540
I don't think I have a spare one of those...
bill lumberg wrote: ↑Thu Aug 05, 2021 8:09 pm Swapped on a new PR4GT rear. When putting everything back together, the lower brake caliper bolt pulled the threads, all of them, out of the caliper mount, as pretty as you please. There was never any resistance at all.
