Color-rite paint prices have always been crazy expensive...
Pants is setting up his 2021 FJR and has Questions
- x 10997
- x 4234
Re: Pants is setting up his 2021 FJR and has Questions
- x 15846
- x 14954
I looked all over and can't find another exact match for the paint.El Toro Joe wrote: ↑Tue May 02, 2023 9:03 amColor-rite paint prices have always been crazy expensive...
- x 10997
- x 4234
Color-rite kinda has a monopoly on the factory paint codes...and they take advantage of that, through their pricing.
- mcatrophy
- FJRModel: 2018 FJR1300AS
- x 60
- x 664
Mr. Trophy realises that his American friends often need helping out of jams.wheatonFJR wrote: ↑Mon May 01, 2023 2:55 pm ...
Mr. Trophy's pastime seems to be helping Americans out of a jam!
Hppants, danh600, and wheatonFJR loved this
My web site
- x 48411
- x 20490
mcatrophy wrote: ↑Tue May 02, 2023 11:28 amMr. Trophy realises that his American friends often need helping out of jams.wheatonFJR wrote: ↑Mon May 01, 2023 2:55 pm ...
Mr. Trophy has a sense of humour. For sure.
- x 15846
- x 14954
I need to check and loct-tight the torx screws on my saddle bags. Someone must have borrowed my torx bit since the last time I did this.
Can anyone pls confirm which SIZE torx bit this is?
TIA
TIA
- mcatrophy
- x 60
- x 664
T10.
My web site
- x 15846
- x 14954
Thank you, Joe
Also - I have not installed the 1" Bar Risers yet on any of my FJR's.
Confirming that to do this requires me to cut the wire retaining device that holds all of the wires/lines going to the bars and then remove the top part of the triple clamp? This looks a bit more involved than I expected.
Similar to this video:
https://www.youtube.com/watch?v=pHlYvUz962I
- x 5033
- x 6769
I am the turd who sold Pants the risers. I didn't have the installation instructions because my 17 came with the risers. I swapped the risers for a Heli Bridge.
I suggest visiting the Heli web site scroll down a bit to the installation instructions. It will give some good tips on gaining slack needed to install the risers.
- x 4512
- x 2296
IIRC it is a "security T10" with a hole drilled up the center.
Niehart and SkooterG loved this
- x 15846
- x 14954
Thank you both for the reply. small T-bits ordered.
Can you grab the heads with a pair of needle-nose Vice grips or similar? If so, take the old screws out and replace them with Allen cap screws.
- x 15846
- x 14954
I'm going to use the right tool to remove them, and then replace them. I got no problems buying tools - it does aggrevate me when someone borrows mine and doesn't return them, but that's another story.
FJRoss loved this
- x 15846
- x 14954
T-Rex is temporarily out of stock on these:
https://www.t-rex-racing.com/2013-2019- ... n69-13.htm
If anyone has a pair they are interested in parting with, please let me know.
(I know that the engine cages are available, and that they presumably protect better, but I want the sliders.)
Thanks in advance.
Thanks in advance.
- x 15846
- x 14954
My first tank full of fuel yielded 40 mpg. Given the conditions, I would have expected 43-45 mpg. Air filter and air box are clean. Neither front nor rear wheel drags.
Gonna burn a few more tanks and see what happens.
Ride more, stress less.....
- x 6241
- x 10415
Conditions:
Rider has dry spell on his new FJR.
Rider is happy to be riding.
Rider twists throttle, more.
Bike gets crappy MPG.
CraigRegs and Hppants loved this
- x 2429
- x 3269
My 15 has alway gotten 43-45 regardless of how you ride it. That's using ethanol regular. I've used non-ethanol fuel with no change in mpg.
Autozone sells a full set of security torx for around 5 bucks.
Installing 1” riser blocks does include removing the stock assembly and cutting the wire looms attached to them.
- x 15846
- x 14954
Still playing with the stock bars to determine if I"m going with the risers or not. I have seen plenty of videos on how to install them.
Didn't fill up the fuel tank upon arrival back home, but indications are that this tank has yielded what I'd expect. Riding more, stressing less...
- x 5033
- x 6769
To keep Pants' stress level low and keep him riding more I will not post my '17's mpg.
