ES fork and shock rebuilds
x 12285
x 9237
Re: ES fork and shock rebuilds
Hppants wrote: Wed Dec 05, 2018 9:34 am Two-fiddy? Dang, man! That South Carolinian fried chicken is pretty darn good, no?
My '14A is gonna cross 50K either this weekend or the next. Now that I think about it, the rear shock ain't what it used to be. I'm not opposed to the upgrade, it's taking the entire back end of the bike apart that's worrisome.
Replacing the rear shock is a laughable task. Takes me 20 min now. I had to do that a few times with the 04 as I swapped it out between the Penske. It really is a easy job. Might have taken me an hour the first time. That included pictures and watching Youtube and calling TominPA.
Your mileage will not vary ....(at least longer)
250 lbs/113kg(.03 elephants) and you are worried about the spring rate? Riding two-up while packed for a 2 week trip we are at the weight limit of the FJR. Should we have already died? Why does the FJR have such a high weight limit if the spring is over matched at 250 lbs? :stickpoke: When two-up I have problems with excessive inertia(!) in the twisties but don't have handling or ground clearance problems. At EOM '18, did garyahouse or Brody find my pace limited by my suspension? :mrgreen:
x 47373
x 20111
Griff is well over 6ft...so he carries that 250 like nuttin.
griff
x 266
x 756
Post by griff »
My meager understanding of Yamaha suspensions is that they are typically undersprung - so that is why I would look at the spring if refurbishing that rear shock. That and with 115 K miles on that shock tends to make me believe that everything needs a going over.
x 47373
x 20111
griff wrote: Wed Dec 05, 2018 11:03 am My meager understanding of Yamaha suspensions is that they are typically undersprung - so that is why I would look at the spring if refurbishing that rear shock. That and with 115 K miles on that shock tends to make me believe that everything needs a going over.
I think my '13 shock was pretty good for me. At 40K plus miles, it's starting to need help in the twisties...so I will be looking to spend $$$ at Traxion this winter on shock and forks. I hate to send them in now...because the weather will probably turn GREAT as soon as I send them off.
Griff, I don't know how you've put up with that shock for 115k miles. Does it act like a hard tail now?
x 3996
x 6905
The problem with suspension aging is that you don't really notice it until the fuckery makes itself known by doing bad shit (wobbles, tracking, bottoming etc). Its only when you replace it does the bulb click.
x 47373
x 20111
bungie4 wrote: Wed Dec 05, 2018 12:31 pm The problem with suspension aging is that you don't really notice it until the fuckery makes itself known by doing bad shit (wobbles, tracking, bottoming etc). Its only when you replace it does the bulb click.
I noticed when I couldn't keep up with jwilly. That there is also a sure sign.
x 3996
x 6905
wheatonFJR wrote: Wed Dec 05, 2018 12:37 pm
Probably a good thing.. FJR's are terrible offroad.
jwilly, NTXFJR, Prestone and 1 others loved this
x 12285
x 9237
wheatonFJR wrote: Wed Dec 05, 2018 10:57 am Griff is well over 6ft...so he carries that 250 like nuttin.
I do not believe Griff is 250. Maybe with all the gear on, tank bag, and contents of luggage.
And what Bungie said about not noticing until you replace it is the truth. The difference between my worn out 04 at 60K was noticeable, but I learn to adapt to it over a period of time. When the Penske(that was a little worn anyway) was such a huge change, it changed the way I set up corners and the amount of confidence was staggering.
The re-learning curve was steep but very worth it.
When I jumped to the ES that only had about 20K miles on it, I had to relearn the bike again. I have chased some really fast guys on this board. I know I would have never been able to keep them in sight with the 04 regardless of my abilities.
Suspension is everything.
griff
x 266
x 756
Post by griff »
wheatonFJR wrote: Wed Dec 05, 2018 12:27 pm Griff, I don't know how you've put up with that shock for 115k miles. Does it act like a hard tail now?
Gittin used to the Harley I'm gona git :lol:
x 47373
x 20111
Cav47 wrote: Wed Dec 05, 2018 1:16 pm
I do not believe Griff is 250....
As you can see, Griff is a bit taller than I am...he's a veritable Giant.
griff
x 266
x 756
Post by griff »
wheatonFJR wrote: Wed Dec 05, 2018 3:58 pm
Haha - I do look big in that picture. By that way, do I see Trooper Fenwick in the background? :lol:
escapefjrtist and wheatonFJR loved this
x 3436
x 12713
Perhaps we need a separate thread so we don't hijack this one...... so briefly, hang in there...... see Suspension Matrix..... http://www.fjriders.com/forums/viewtopi ... =60&t=2373
True that the light bulb comes on as bungie says. First rule of suspension, the springs have to carry the weight of bike and rider properly. If it doesn't you are playing with settings trying vainly to get it to carry your weight, if those settings exist.... it's a compromise. Ignore damping for the moment, talks springs only. For 200 lb. rider, we need 1.0 fork springs, 800-850 lb. rear shock spring (despite what the matrix says). Talking from experience and spending money to find out what works. With a little bit of preload, the spring coils will remain nicely spaced and give you a plush enough ride, to which you can add damping to essentially control any pogo effect, the idea being use the least amount of damping it takes to get the job done.
We can discuss A vs ES, but in keeping with this thread... ES rear shock has a 685 lbs. spring, good for ~160-ish lb.rider, but you can add preload. For two up, pretty much maxed out, and I know several one-uppers run at two-up preload settings. Any discussion on damping will just complicate things, so let's just say........ ES needs more spring on the back end, and once you have it, damping can be set to something more suitable for the nicer ride (again, any talk of ES damping will just bring out another set of complications... the whole thing is a compromise).
As for the A rear shock, you have (on Soft) the equivalent of a 651 lb. spring, with no preload option except to dial in Hard (976 lbs). Neither is likely to be good one-up, so you dial in rebound damping, a compromise also..... no sense re-springing an A shock, go aftermarket so you get some preload adjustment you can tweak...
x 47373
x 20111
Thanks for relinking that thread...I totally alzheimered that one away.
Prestone
x 182
x 137
Post by Prestone »
Picking up my stock shock tomorrow. Finally got the dealer to give it to me.
griff, wheatonFJR, and Cav47 loved this
jwilly
Site Admin
x 2249
x 2148
Post by jwilly »
Shit I guess I better get my bike over to Traxxion!
x 3436
x 12713
My advice, fork-wise, is upgrade the springs if you need them but don't spend any money on valving until you've had the new springs a while. The OEM valving is decent as it is. Do move up to a touch heavier oil to say 7-8W or maybe 10W. ES doesn't need fork springs, the rest do, but if you're light enough (under 200), the Gen3A progressive springs might be OK if you wind in the preload.
Spend the bucks on the rear...... new springs for the ES or aftermarket suspenders for the A's.
x 15301
x 14210
Going to the Showa 7wt oil made a noticeable difference on my '14A model. Dampening is smoother. Hard bumps are just a touch harsher, but if I back out the pre-load, she gets spongy when she's pushed, so I put up with the occasional harsh bump.
x 3436
x 12713
Hppants wrote: Wed Dec 12, 2018 9:14 am Going to the Showa 7wt oil made a noticeable difference on my '14A model. Dampening is smoother. Hard bumps are just a touch harsher, but if I back out the pre-load, she gets spongy when she's pushed, so I put up with the occasional harsh bump.
Try backing out the compression damping instead. Rule #1, the springs have to carry you and bike.
x 13145
x 6352
So, late to this thread, but:
At around 35k, my rear shock was toast. I went to my Yamaha dealer and talked to my service guy. I had YES and we had a conversation about my shock wearing out. He had a 2001 Honda ST1100 with around 200k and said his shock was still going strong. I know he wasn't realizing the slow wear, but this worked in my favor.
I told him my shock was locked out at full settings and still bottoming out and causing ride issues. We agreed that a shock on a ~$13,000 MC should last longer than 35k. So, he took my bike for a 5 minute ride. He came back and said, "Yeah, its bouncy. It shouldn't do that. Let me call our rep." He called Yamaha and they agreed to replace the shock under warranty. I got a brand new shock out of it. Other than being worn there was nothing wrong with the unit. For sure, no leaking or anything like that.
I replaced that new shock with a rebuilt Wilbers snd absolutely love it. The difference is amazing. And I'd never get another FJR without either the ES or immediately upgrading the suspension, to include the valving in the forks. Blah blah blah, we've all heard that before. Point is, Yamaha replaced my worn out shock with no exterior defects under warranty. You might want to give that a shot.
