Ages ago, I hardwired my garage remote to a PTT button mounted on a small waterproof hobby box I picked up from Radio Shack. I then mounted the remote hidden someplace in the fairings where it wouldn't likely get wet. I had a few other buttons on the box as well, including one to put the bike into dealer mode to display codes. Retarded to put the dealer mode switch under the rear cowling where you have to turn off the bike to open the back and turning the bike off would clear that specific code. Anyway, I used industrial velcro to mount the box somewhere convenient. Very similar solution to kieefjr's which required no modifications to the bike and had more than one use.
Now, with multiple bikes in my garage, the remote just lives in my jacket pocket so I always have it.
DesignFlaw06, I like that delay relay, might have to look into messing with one of those.
Garage door opener hard wired
- x 6084
- x 10032
Re: Garage door opener hard wired
- Uncle Hud
- x 7246
Gotta have smartphone-capable gloves to work the app, I suspect. "They" are conspiring to keep money from accumulating in my bank account.
- x 47256
- x 20078
garage door opener in left overpants pocket...done.
- Uncle Hud
- x 7246
Good solution, Wheatie! (I've got my opener screwed to the underside of my dashboard shelf.)
- silverback
- x 1250
Re: RE: Re: Garage door opener hard wired
I just used double sided tape to stick mine in the glove box.Uncle Hud wrote:Good solution, Wheatie! (I've got my opener screwed to the underside of my dashboard shelf.)
- x 10729
- x 4133
I used velcro, to attach mine to the inside of the glove boxsilverback wrote: ↑Wed Nov 15, 2017 6:14 pmI just used double sided tape to stick mine in the glove box.Uncle Hud wrote:Good solution, Wheatie! (I've got my opener screwed to the underside of my dashboard shelf.)
- x 3431
- x 12686
I took that one step further by removing the electric lock solenoid, which lets me open the glove box without the ignition having to be on... handy a few times already.El Toro Joe wrote: ↑Wed Nov 15, 2017 6:55 pmI used velcro, to attach mine to the inside of the glove boxsilverback wrote: ↑Wed Nov 15, 2017 6:14 pmI just used double sided tape to stick mine in the glove box.Uncle Hud wrote:Good solution, Wheatie! (I've got my opener screwed to the underside of my dashboard shelf.)
- x 10729
- x 4133
If I'm using the garage door opener, the bike is usually runningraYzerman wrote: ↑Wed Nov 15, 2017 7:18 pmI took that one step further by removing the electric lock solenoid, which lets me open the glove box without the ignition having to be on... handy a few times already.El Toro Joe wrote: ↑Wed Nov 15, 2017 6:55 pmI used velcro, to attach mine to the inside of the glove boxsilverback wrote: ↑Wed Nov 15, 2017 6:14 pm I just used double sided tape to stick mine in the glove box.
- Madmudder
2023 FJR1300es Cobalt Blue
- x 1853
- x 381
I found the keychain remotes did not work from far enough away. I went to the scrap yard and took the factory one from a Mercedes and put it behind the fairing above the headlight and ran a wire for a remote switch that works with the ignition. Now I can round the corner on my street hit the button and garage is wide open when I get to it. Works just as I hoped it would and for less than $20.00 wire & switch included.
gixxerjasen loved this
2014 FJR1300es
