Ok ya gotta come clean now, spoon feed us and don't make us hunt for it, what was the 2nd no start issue? Fess up already...Gen 3 vs gen 2 sensor? Overlooked connector? (though doubtful for you).
John d
FJRModel: 2008A
x 929
x 647
Post by John d »
Story is not over, but its two fouls and a hit out of the park. Congratulations, I knew you could do it.
spklbuk
x 3352
x 6845
Post by spklbuk »
BAM!
Montani Semper Liberi
x 10996
x 4232
Sounds good, and it looked like all the gauges even work. I wouldn't expect any less...
x 12948
The whole thing was pretty simple really, you can't really put anything together wrong, all the wire connectors are rather unique, or laid out by Yamaha such that you can't plug one into the wrong mate. Once done, and battery hooked up, turn the key and all the juice flows to wherever it's supposed to go. All you need is air, fuel and spark, and to be able to spin the engine over..... I've never been worried about any of this.
It was untimely that the starter relay crapped out.... beyond anyone's control. Actually very timely, I'd rather replace it now than have an unhappy new owner. The starter, well, my fault there, but easily dealt with. So why wouldn't it start?
When I turned on the ignition, the fuel pump cycled and primed the fuel rail and shut off as expected. You may have noticed the low fuel bar was flashing..... Then I raised the tank and the attempt to start failed because there wasn't enough fuel for the pump to pump....... Back when I was organizing things on the shelf, the fuel tank was rather full and when it warmed up to room temp, some fuel pushed out of the vent. So, I drained 20 litres out and figured there was a couple litres left in there...... so Hack and I let the tank down, it fired right up, let run to check all possible leak areas (none) and get to operating temperature, then cool down. Video 3 would come later as we had other things to do that day... by then I had added fuel, and left the tank down just because I didn't need it up. Fuel light still flashing because I still haven't reset it. All worked as expected, we have a perfectly functioning bike.
Forgot to check the heated grips..... need the bike running to feed enough voltage to the controller.... I suspect that's all it is.
CraigRegs, Steel_Gin, Auburn and 3 others loved this
STrep
FJRModel: 05 ST1300
x 2
x 2
Post by STrep »
raYzerman wrote: Sat Feb 16, 2019 9:34 pm The whole thing was pretty simple really, you can't really put anything together wrong, all the wire connectors are rather unique, or laid out by Yamaha such that you can't plug one into the wrong mate. Once done, and battery hooked up, turn the key and all the juice flows to wherever it's supposed to go. All you need is air, fuel and spark, and to be able to spin the engine over..... I've never been worried about any of this.
Thank you for the information Ray
x 1647
Most coolio! Congrats Ray.. well done!
x 2625
x 2114
Congrats Ray, you did good!
NBB
FJRModel: 2015A
x 252
x 71
Post by NBB »
Congrats Ray, I enjoyed the read along on this project.
NBB
x 9714
x 4127
It works when giving it some fuel. Just like all the others.
spklbuk
x 3352
x 6845
Post by spklbuk »
So what ya gonna do now that your project bike will no longer whisper in your ear at 3 a.m.?
x 48407
x 20490
spklbuk wrote: Sun Feb 17, 2019 5:38 pm So what ya gonna do now that your project bike will no longer whisper in your ear at 3 a.m.?
Oh, I think yamafitter is doing that now...
Bust, Steel_Gin, and FJRPittsburgh loved this
x 12948
I have to put some lipstick on it so it will still whisper a little bit. Gotta climb in bed with the WR and put a jet kit in it. That won't take but part of a day, but I might just pull the carb right off and give it the spklbuk-approved ultrasonic spa treatment. Other things going on too, but also have to give Root Beer some massaging. All my girls require maintenance....
Steel_Gin, Madmudder, Hppants and 1 others loved this
wnyfjr
FJRModel: 06 AE
x 514
x 674
Post by wnyfjr »
raYzerman wrote: Sun Feb 17, 2019 6:43 pm All my girls require maintenance....
Ain't that the truth... (Laura's not reading over my shoulder, is she? :? )
Steel_Gin, Madmudder, and FJRPittsburgh loved this
Madmudder
FJRModel: 2014 FJR1300es Metallic Black
2023 FJR1300es Cobalt Blue
2022 Honda Goldwing tour DCT Blue
x 1859
x 381
Post by Madmudder »
wnyfjr wrote: Sun Feb 17, 2019 8:17 pm
I'll ask her next time I see her just to confirm :)
Cav47, Steel_Gin, FJRPittsburgh and 2 others loved this
2014 FJR1300es
wnyfjr
FJRModel: 06 AE
x 514
x 674
Post by wnyfjr »
Madmudder wrote: Mon Feb 18, 2019 6:31 pm
I knew I could count on you to "help" Tim. :shock:
Steel_Gin, FJRPittsburgh, Madmudder and 2 others loved this
Steel_Gin
FJRModel: 2012 FJR1300A
x 1428
x 446
Post by Steel_Gin »
wnyfjr wrote: Mon Feb 18, 2019 6:41 pm
If Tim can't make it to Tech Day I can run that question by Laura if that would help. :D
Madmudder loved this
x 48407
x 20490
I see that this thread has devolved into "ways to screw a certain New Yorker".
That sounds like a Ray thread.
Bust, Steel_Gin, wnyfjr and 1 others loved this
BikerGeek
x 5421
x 4737
Post by BikerGeek »
wheatonFJR wrote: Tue Feb 19, 2019 3:02 pm I see that this thread has devolved into "ways to screw a certain New Yorker".
Sure as hell beats a "Going to Cleveland" thread. JSNS
Awesome stuff, Ray!
Bust, wnyfjr, and Festus loved this
RacinRay
x 172
x 874
Post by RacinRay »
What's wrong with going to Cleveland if you're driving?
