Gen 3 surging
x 14699
Re: Gen 3 surging
Festus wrote: Sun Jul 02, 2023 9:06 am Since mice ate the wiring up when we got her, maybe there's a bad wire somewhere that we never saw?
This.
I had a weird electrical issue with my '94 Grand Cherokee - auto antenna would go up and down, radio would go in and out, one rear turn signal work work interimittently, other things, it seemed completely random. A shop spent 3 days trying to run it down with no luck. When I finally got feed up with it, I ripped into it. I found that when I "repair" a loose heat shield underneath the unibody, I ran a self-tapping screw through the floor to hold the heat shield (and keep it from rattling) and ran it right into a wire bundle on the inside of the cabin below the carpet under the rear seat. There was a section of wire bundle that, over about 6 months, had slowly shorted out and heated up to the point of melting the wire cover. I replaced a 12" section of wire bundle - there was about 10-15 wires in that section of the harness.
Long story short - if you know that there was mice in the bike chewing on stuff, it seems fairly reasonable that this sickness could be caused by a section of wire harness being mangled enough to ground out against other wires. It could be nearly invisable depending on where it is.
With all the parts that have been thrown at this with no resolution, I'd start looking hard at the wire harness - which is a project that would involve stripping the bike down to the frame.
Just my .02...
Viper_Dad
FJRModel: 2013
x 469
x 466
Re: Gen 3 surging
Post by Viper_Dad »
I ran the diagnostics and here's the codes she's showing along with the brief description of each as provided in the service manual:
13 - Intake air pressure sensor short circuit detected
15 - Throttle position sensor short circuit detected
19 - Side stand switch broken lead at ECU
21 - Coolant temperature sensor short circuit detected
23 - Atmospheric pressure sensor short circuit detected
30 - Latch up detected
70 - Engine idling stop
90 - Front brake light switch and rear brake light switch short circuits detected
I did not clear the codes yet, figured I would post them here first. I assume the next step is to clear the codes, take her for a spin, then check the diagnostics again? And I agree, so far all signs point to that mischievous mouse! :angry:
2013 - "Jolene"
Peter
x 953
Re: Gen 3 surging
Viper_Dad wrote: Mon Jul 10, 2023 10:48 pm I ran the diagnostics and here's the codes she's showing along with the brief description of each as provided in the service manual:
Wow!!
It will be interesting to see how quickly (or if) these return once they are cleared.
#13, 15 and 23 could all be significant in view of what is happening. Even sidestand (19) could cause dropouts.
(How did we get this far without looking at fault codes?)
Viper_Dad loved this
x 3517
x 12938
Re: Gen 3 surging
Clear them...... I suspect all triggered by having the battery disconnected and reconnected at some point who knows when..... the bike is running, so all of that history does not apply, nor does it matter. What matters is now. Go ride for half an hour come back and go back into DiAG and tell us what you got.
Viper_Dad and wheatonFJR loved this
x 953
Re: Gen 3 surging
raYzerman wrote: Tue Jul 11, 2023 7:41 am Clear them...... I suspect all triggered by having the battery disconnected and reconnected at some point who knows when..... the bike is running, so all of that history does not apply, nor does it matter. What matters is now. Go ride for half an hour come back and go back into DiAG and tell us what you got.
Agree 100%. If they don't come back, it was probably an electrical glitch at some point - connecting/disconnecting the battery or cranking with a weak battery with subsequent start failure.
If faults do come back, there is something to work with!
x 14699
Re: Gen 3 surging
Here, I have a solution.
Step 1 - Sell this POS to me as is. I have 5 Benjamin's burning a hole in my pocket.
Step 2 - Google closest Yamaha dealer
Step 2a - strike that, you already know where the closest Yamaha dealer is with a FJR in stock...
Step 3 - Go buy it.
I'll swing down before EOM with the trailer and pick POS up to get it out of your way and hair...
Friends helping friends... :)
FJRPittsburgh, Viper_Dad, El Toro Joe and 2 others loved this
Viper_Dad
FJRModel: 2013
x 469
x 466
Re: Gen 3 surging
Post by Viper_Dad »
extrememarine wrote: Tue Jul 11, 2023 8:26 am Here, I have a solution.
Step 3 - Go buy it.
Hahaha this made me LOL for real. There's a '23 at my local dealer with 1 mile on it and I have pondered that purchase a lot lately. Now if only I had $18,299 just lying around.
Back to reality, I'll clear the codes and ride her tomorrow after work and see what comes up!
FJRoss and wheatonFJR loved this
2013 - "Jolene"
Peter
x 4463
x 12609
Re: Gen 3 surging
Viper_Dad wrote: Tue Jul 11, 2023 1:31 pm Hahaha this made me LOL for real. There's a '23 at my local dealer with 1 mile on it and I have pondered that purchase a lot lately. Now if only I had $18,299 just lying around.
I double dog dare you to buy it :D
FJRPittsburgh, blind squirrel, and wheatonFJR loved this
blind squirrel
FJRModel: 2014
x 1590
x 2633
Re: Gen 3 surging
Post by blind squirrel »
Festus wrote: Tue Jul 11, 2023 1:39 pm
If you TRIPLE dog dare him, he will HAVE to do it! But you better expect the fire department and the cops to show up after he does.
x 14699
Re: Gen 3 surging
Update - all you need is $17,799 because I'm going to give you $500 when I pick up the mouse nest...
:D
Someone's going to stumble across this and make a comment about why I don't have a T7 in the garage yet - I present exhibit A and B, which required Exhibit C.
Exhibit A:
Exhibit B:
Exhibit C:
Toter, FJRPittsburgh, Viper_Dad and 1 others loved this
x 48395
x 20486
Re: Gen 3 surging
I think there is already a 2023 vin number with his name on it.
x 4463
x 12609
Re: Gen 3 surging
extrememarine wrote: Tue Jul 11, 2023 2:23 pm Someone's going to stumble across this and make a comment about why I don't have a T7 in the garage yet - I present exhibit A and B, which required
I'm not up on my current market pricing but I'd think you could more than cover the cost of the T7 if you sold all of those things :)
blind squirrel and wheatonFJR loved this
x 14699
Re: Gen 3 surging
I smell what you're cooking, and it smells like a poor decision. I've made enough of those in my life already...
Festus wrote: Tue Jul 11, 2023 2:39 pm
Viper_Dad
FJRModel: 2013
x 469
x 466
Re: Gen 3 surging
Post by Viper_Dad »
Cleared the codes. Rode her 40 miles. Checked her diagnostics again. No codes. Surging is still there.
Crap.
2013 - "Jolene"
Peter
x 953
Re: Gen 3 surging
Check again after another couple hundred, but I suspect the codes were a red herring. Would have been nice if one pointed to a probable faulty device.
Can't remember if you tried running with the O2 sensor disconnected. Not sure how a Gen III would behave but I know a Gen II doesn't mind. I also know that a Gen II does mind an incorrect O2 reading. (Long story)
x 1466
x 3562
Re: Gen 3 surging
Drop that thing off here and I will go through the harness to check for other rodent damage.
FJRPittsburgh and LKLD loved this
x 2423
x 3264
Re: Gen 3 surging
Approaching 3 years of spanking the monkey on this problem, throwing parts at it, and 3 years of enjoyable riding lost. Paying a professional good money 3 years ago to fix it may have cost some money, but, well spent if it delivered a bike you could have been enjoying. Life's too short to fight something so long. 11 pages........
x 4463
x 12609
Re: Gen 3 surging
Toter wrote: Tue Jul 25, 2023 10:43 pm Approaching 3 years of spanking the monkey on this problem, throwing parts at it, and 3 years of enjoyable riding lost. Paying a professional good money 3 years ago to fix it may have cost some money, but, well spent if it delivered a bike you could have been enjoying. Life's too short to fight something so long. 11 pages........
I think you are misunderstanding the situation. When I have said "Let's work on it", he said "Screw that, let's go riding". No riding has been lost.
There's no one in this area I'd let change the oil, much less work on my motorcycle. It'll get solved. Viper Dad has had a very busy life for the last couple of years. When things settle down, I'm confident it'll be resolved.
FJRPittsburgh, Toter, LKLD and 1 others loved this
x 3517
x 12938
Re: Gen 3 surging
I don't think the "professionals" would have done as much or been as thorough..... they would have thrown parts at it too. That said, I'd like to have that bike for a few days to check it out myself.
FJRPittsburgh, wheatonFJR, and LKLD loved this
x 4463
x 12609
Re: Gen 3 surging
There's a FB group for FJR mechanics. I posted about this issue on there. Someone posted that we need to swap the Mass Air Flow Sensors. I questioned where they were, since the manual didn't list anything as Mass Air Flow Sensors. Silly me for asking a question, the person that said that responded "Then don't listen to me".
I thought it was an honest question, but I guess not, but none the less, it's the 2 sensors on top of the throttle bodies. Same part number for both. Viper Dad finally swapped them a week ago and it changed nothing.
I guess the last step is swapping the ECU? Any harm in doing that between our bikes? Just unplug and swap?
