Trailer Hitch set up
x 1716
x 2627
Re: Trailer Hitch set up
natehawk750 wrote: Mon Nov 11, 2024 10:21 pm
wheatonFJR wrote: Mon Nov 11, 2024 9:28 pm
natehawk750 wrote: Mon Nov 11, 2024 6:10 pm
I don't have anything yet... I was going to start with a hitch and figure out the trailer after. I do know that I need a hitch that will work a darkside tire.
I may be mistaken, but I thought Bryan/Auburn is a darksider.
I believe so.
On a Goldwing for a while now. I may be wrong, but I believe he never Darksided his FJR and when had a trailer with it.
Auburn
FJRModel: other ride
x 2420
x 1476
Post by Auburn »
Auburn wrote: Mon Nov 11, 2024 5:01 pm That is a Bushtec hitch and trailer. Best Hitch you can get. Best trailer too. It does use a pin with a Heim joint connection. Not sure if he has the hitch that has the pin bolted in or welded in. Depending on the trailer you have Nate will mater. If it is a welded in pin, you can cut it off and drill for a regular ball if that is what your trailer needs.
Bushtec hitch will work darkside, depending on the tire used
get out and ride!
IBA #708
2024 Goldwing
Auburn
x 2420
x 1476
Post by Auburn »
SkooterG wrote: Tue Nov 12, 2024 12:37 pm
I believe so.
Correct, never darksided my FJR, but darkside will work with bushtec hitch on the FJR. (depends on the tire used)
Depending on what Nate wants to do, I could build him a custom hitch. Would need access to a bike locally to do it for him. I would do it similar to the Bushtec, but also make so the back could come off and allow tire removal instead of dropping the wheel out the bottom.
gixxerjasen and SkooterG loved this
get out and ride!
IBA #708
2024 Goldwing
natehawk750
x 2179
x 2474
Post by natehawk750 »
Auburn wrote: Tue Nov 12, 2024 2:08 pm
I believe so.
I have been toying with the idea of just fabbing up my own.
Auburn loved this
#69272
blind squirrel
FJRModel: 2014
x 1593
x 2633
Post by blind squirrel »
Intech wrote: Tue Nov 12, 2024 11:10 am Why do you all want to give away my hitch? I will be converting it to carry large flags for Patriot Guard Missions, so it will not be going anywhere.
Did I mention cost or lack of cost? :stickpoke:
fjrob
FJRModel: 03
x 388
x 846
Post by fjrob »
Nate I'll send you some pics tomorrow of my hitch. Easy to fab. You're kind of handy.
wheatonFJR and natehawk750 loved this
#1 frost back!!!
natehawk750
x 2179
x 2474
fjrob wrote: Wed Nov 13, 2024 7:27 pm Nate I'll send you some pics tomorrow of my hitch. Easy to fab. You're kind of handy.
Thanks!
#69272
x 48432
x 20501
Was going through an old thread and have a better photo of Duane's bike with the hitch attached.
0face, SkooterG, and natehawk750 loved this
fjrob
FJRModel: 03
x 388
x 846
Post by fjrob »
My hitch. Image
D-Eagle, Auburn, Cav47 and 1 others loved this
#1 frost back!!!
fjrob
FJRModel: 03
x 388
x 846
Post by fjrob »
FJRPittsburgh, Auburn, Cav47 and 3 others loved this
#1 frost back!!!
Auburn
x 2420
x 1476
Post by Auburn »
fjrob wrote: Thu Nov 14, 2024 9:15 pm My hitch. Image
are you using solid bar or tubing for the bottom piece?
get out and ride!
IBA #708
2024 Goldwing
fjrob
FJRModel: 03
x 388
x 846
Post by fjrob »
Square tube.
#1 frost back!!!
JoelTheMole
x 46
x 38
Post by JoelTheMole »
Who all still makes FJR1300 hitches? Been thinking I want to get one before they all disappear...
Spininprop and Mossyrocks loved this
