Updates and Opinions Needed (Quickly)
x 910
x 2664
Re: Updates and Opinions Needed (Quickly)
I'm guessing that there is arguably more stress on second gear than any other; especially during rapid acceleration. Not a function of inferior material.
Second is more likely to be problematic on lots of bikes. Especially gear dogs and shift forks.
danh600 loved this
Pathfinder
FJRModel: 2005/2008/2009/2018/2018
x 77
x 203
Post by Pathfinder »
The recalls on my ‘18 were done. First I received the gear recall and then some time after that was complete I received the 2nd recall notice for the ECU reflash.
Pathfinder
x 77
x 203
SkooterG wrote: Thu Oct 31, 2024 10:53 pm If you decide to go this route contact me and I'll give you the contact info on the dealer I bought mine from. IIRC, it was $375?
You should be able to do better than $18.2k, especially on a '23. There are dealers that will deal. I can think of four off the top of my head you could contact. Two in West Virginia, one in North Carolina, and one in Oregon.
https://albany.craigslist.org/mcd/d/cox ... 33866.html
PM Inbound for you.
natehawk750 loved this
Dan Cooper
FJRModel: 2014-A
x 251
x 216
Post by Dan Cooper »
SkooterG wrote: Thu Oct 31, 2024 10:53 pm 4 year Y.E.S. is time based with unlimited miles. Typically, you can extend it another 2 years to get a total of 7 years of unlimited miles factory warranty. If you decide to go this route contact me and I'll give you the contact info on the dealer I bought mine from. IIRC, it was $375?
You should be able to do better than $18.2k, especially on a '23. There are dealers that will deal. I can think of four off the top of my head you could contact. Two in West Virginia, one in North Carolina, and one in Oregon. These are the dealers that were selling '23 FJRs for about $15.3k a year ago. No doubt any dealer with a '23 FJR on hand is motivated to get rid of it. Especially with the announcement of the '25 FJR imminent. I would be surprised if Yamaha doesn't have some sort of incentive given to dealers to sell 2023 FJRs.
If you don't go new there is always something like this?
Correct me if I'm wrong, but I seem to recall that the new surplus Police model FJRs sold to the civilian market are sold without any warranty of any sort, and they are not eligible for the YES extended warranty.
dan
x 11601
x 10809
x 6079
x 10024
FJRoss wrote: Fri Nov 01, 2024 9:24 am I'm guessing that there is arguably more stress on second gear than any other; especially during rapid acceleration. Not a function of inferior material.
Yep, there's been a number of bikes over the year with 2nd gear problems. I recall the gixxers having issues with their "Wheelie" gear. Which is exactly how Suzuki approached those issues, people bitch about Yamaha cracking open the engine for the repair, but at least they did the warranty instead of telling their customers to stop doing wheelies and go pound sand.
x 3429
x 12678
There is a very large thread on the 2nd gear debaucle on FJR Owners. The original second gear was a casting and since they had to put 6 gears in where 5 used to be, they got thinner.... the failures had either broken teeth or chunks of gear/shattered and of course, got all balled up in other fast moving parts and destroyed a few engines..... the new gear is a forging. The initial ECU flash was like a rev limiter at ~3500 in second... due to complaints and NHTSA getting involved, they increased that rev limiter to 6000 rpm, thus all got a second reflash to fix the first.
CollingsBob and SkooterG loved this
x 15236
x 14112
I don't understand - the ECU is supposed to limited rpm to 6,000 in second gear?
x 5995
x 10131
I know exactly one person that had a second gear failure on an FJR. That was on a 5 speed.
Was it really that common of an issue?
x 1437
x 2108
Hppants wrote: Fri Nov 01, 2024 4:24 pm I don't understand - the ECU is supposed to limited rpm to 6,000 in second gear?
I am fairly certain that the ECU limited RPM was strictly when feathering the clutch.
Also according to the little bird that whispers in my ear the Police Departments that had FJRs were a big complainer and impetus for the increased rpm of the 2nd recall.
x 1437
x 2108
Dan Cooper wrote: Fri Nov 01, 2024 12:14 pm
dan
That is correct.
x 3429
x 12678
SkooterG wrote: Fri Nov 01, 2024 5:49 pm
Yes, it is while feathering the clutch... apparently a few rev up their FJR's beyond 3500 rpm while slipping the clutch..... and the rev limiter would kick in..... the complainants felt this was dangerous, so the second ECU reflash upped the rpm to 6000 in that scenario.
wheatonFJR and SkooterG loved this
