Morgan Carb Tune Pro
x 3517
x 12938
Re: Morgan Carb Tune Pro
The Gen3 runs on minimum vacuum, so the painted one was dialed all the way in, and the rest sync'd to it. If you can, then great....
Depends where the sync was before you removed all the screws... in some cases the reference changed or Yamaha didn't have it right in the first place...... if you couldn't sync one of the screws and had that one dialed all the way in as well..... in that case, the second one becomes the reference and you back all the others out to sync. But, you always have one screw all the way in.
Festus and SkooterG loved this
x 12299
x 11215
dcarver wrote: Sat Apr 13, 2024 6:20 pm
fontanaman wrote: Fri Apr 12, 2024 5:23 pm The question I posed remains. Does the Carb Tune have enough sensitivity given its minor graduation marks are 10 times less sensitive than Yamaha advises. Beat the horse to death.
Next weekend I'll grab both of my Morgan's and take them to the Metrology Lab I manage at the nuke plant. There I can perform quantitative testing with NIST traceable standards to determine, within 3 sigma, the sensitivity value of each of the 8 channels. Not kidding :D
While I'm at it, I'll determine accuracy too! :lol: :lol:
Edit - this will have to be static testing. Can't replicate dynamic conditions.
Did you ever?
Boston
x 128
x 187
Post by Boston »
"applied appropriate suckage" lol
Good luck getting anything dialed in with dirty throttle bodies and injectors.
IBA# 76760
x 2419
Here's a blast from the past. I used to use a set of 4 vacuum guages attached on rack. There were variable restrictors in the lines to level out the pulses of the needles. Occasionally, I would hook each guage to the same vacuum port to ensure they were reading the same. Still have that set of guages, and bet they would still do the job.
bigjohnsd, raYzerman, wheatonFJR and 1 others loved this
x 5032
x 6765
natehawk750 wrote: Tue Sep 03, 2024 10:48 pm
fontanaman wrote: Fri Apr 05, 2024 6:00 pm I used to be an hardware configuration auditor at Boeing. I got kind of good at this job but got tired of the job because "here comes the badass auditor" wears on ya after a while. I am sure these days it wouldn't take long for me to drive them batshit once again.
Oh... you were THAT guy...
Damn right I was that guy!
natehawk750 and wheatonFJR loved this
x 1712
x 2624
fontanaman wrote: Wed Sep 04, 2024 11:46 pm
And based on you starting this thread, you still are!!! :lol:
fontanaman, natehawk750, bigjohnsd and 1 others loved this
Powerman
FJRModel: 06fjr
x 326
x 1744
Post by Powerman »
Blast from the past
Last time I had needle gauges taped to a rag on a bike was the 70's.
Also the first time I was pulled by the law on a bike, testing might have been a little spirited.
Got off with a warning.
x 5032
x 6765
SkooterG wrote: Thu Sep 05, 2024 11:40 am
Darn right and proud of it! :D
x 48381
x 20486
fontanaman wrote: Thu Sep 05, 2024 11:45 pm
So...Im guessing that the publicized QC issues at Mother Boeing would especially irk you.
x 5032
x 6765
wheatonFJR wrote: Fri Sep 06, 2024 8:55 am
Absolutely. The 737 door plug blowout was caused by a failure to follow written procedures. When I worked there following the procedures was adhered to.
Now I am jacking my own thread.
x 1712
x 2624
fontanaman wrote: Fri Sep 06, 2024 8:21 pm
Ewwww! I hope you have a tissue! :bustinlove:
bigjohnsd and fontanaman loved this
x 3517
x 12938
I wasn't clear on who it was responsible for the door plug bolts loose.... wouldn't that be the maintenance crew's job if they had the door off and didn't put it back properly by the book? I'm assuming that plane wasn't brand new......
x 5032
x 6765
raYzerman wrote: Fri Sep 06, 2024 9:22 pm I wasn't clear on who it was responsible for the door plug bolts loose.... wouldn't that be the maintenance crew's job if they had the door off and didn't put it back properly by the book? I'm assuming that plane wasn't brand new......
The plane was brand new and there is no maintenance required on door plug fasteners.
Here is how it played out.
The door plug is installed complete at the supplier and shipped to Boeing, meaning Boeing doesn't have to do (a f*ck thing) anything. Boeing Quality Assurance writes a discrepancy notice on the rivets in the door plug. The only way to fix the rivets is to remove the door plug. A removal record was not written per Boeing procedures so the responsibility and evidence of work complete was lost in the shuffle of shifts changes and time. The removal record would have included the steps to complete reassembly including installation of the the bolts and the progress of the work.
x 1647
From eBay for $350 + $50 for insurance plan. Sells new for $800 - $1,200.
From a canine rescue org.. I don't think they knew it's true value.
All indications are this has never been used.
The bag with adapters is still stapled.
Got this for removing kz1300 sparkplugs!
x 3517
x 12938
I have the Vacuumate also. Paid the same used. Score!! Works awesome.
