Ivan's ECU Flash Review
x 4466
x 12620
Re: Ivan's ECU Flash Review
raYzerman wrote: Sat Jun 03, 2023 8:18 pm
chazglenn3 wrote: Sat Jun 03, 2023 2:56 pm The flash for me was worth it just to stop the decel popping thru my Staintune cans. Then again, the low speed jerkiness being gone is awesome too!
That's the PAIR system at work...... didn't know if Ivan could disable it (leave solenoid in the closed position). You could just remove the PAIR system.
Ivan does disable it.
x 9720
x 4127
Ivan's flash leaves the PAIR system solenoid in the closed position.
x 15866
x 14988
With the stock cans, and the PAIR system enabled, I get zero decel popping. Is that an "aftermarket exhaust only" thing?
x 9720
x 4127
I guess so. I've never had any decel popping on any of my stock FJRs.
x 12959
Stock cans mask it very well....
I don't notice decel popping with Staintunes. Are you using the quiet inserts? (I am on my 2011)
x 15866
x 14988
raYzerman wrote: Sun Jun 04, 2023 7:54 pm Stock cans mask it very well....
I dunno - I listened VERY carefully yesterday while out on the bike and didn't hear anything of the sort. I do think that I get the theory - it's kind of like introducing an exhaust leak, no?
x 12959
The PAIR system works by passively allowing air to enter the exhaust after combustion. There is a hose from the airbox (filtered air) to the solenoid. The solenoid opens on decel under certain conditions, air is simply sucked into each PAIR port from the vacuum created by the exiting exhaust. There are reed valves to prevent backflow if the exhaust happens to be under pressure. The air is just meant to burn up unburned gasses in the exhaust, assisted by the heat of the cats. It can pop occasionally on decel.
Yes it is an exhaust leak of sorts. You'd get the same popping if you had a leak at any joint in the exhaust, e.g. no gaskets in the headers or where the mid-pipes joins the headers. FYI, Delkevic includes an RTV type sealant with their system, which you apply prior to assembling the system, meant to seal any small leak that could happen (the pipes fit pretty precisely, so really not likely).
You can remove any PAIR system with the appropriate block-off plates. On Gen3, if you remove the solenoid, it will generate an error code if it senses the solenoid missing (one could install a resistor in the connector if you really wanted the solenoid gone).
Hppants and FJRPittsburgh loved this
chazglenn3
FJRModel: 2008 FJR1300A
x 65
x 32
Post by chazglenn3 »
FJRoss wrote: Sun Jun 04, 2023 7:58 pm
No baffles. If you removed the PAIR system you wouldn't get the decel popping. I just never wanted to remove the PAIR.
chazglenn3 wrote: Wed Jun 07, 2023 1:35 pm
I removed the PAIR a long time ago. I never ran the Staintunes without the inserts - I should try sometime. It is pretty quiet (not a bad thing, IMHO), but doesn't have a great sound.
chazglenn3
x 65
x 32
They have a really nice mellow sound without the baffles. I had a guy walk over to me at Lowe's one day just to ask about the exhaust because he thought the sound was awesome.
FJRoss loved this
chazglenn3 wrote: Wed Jun 07, 2023 2:44 pm They have a really nice mellow sound without the baffles. I had a guy walk over to be at Lowe's one day just to ask about the exhaust because he thought the sound was awesome.
Mine came on the bike when I bought my 2011 four years ago. Just never tried them without the baffles - I will definitely give it a try.
chazglenn3 loved this
chazglenn3
x 65
x 32
I think you will like it. Of course my Hardly riding friends still say it's way too quiet...
FJRoss loved this
x 3046
x 3262
I've mostly only been on this forum, so only heard of Ivan's flash on FJR's. This past weekend I was in Canada on a ride. Talking with some guy riding a Kawasaki Vulcan 1700 and he says he had to get it flashed by some guy....and paused. I said "Ivan?", and he said yeah that's the guy. Said it ran a ton better after getting that done. Night and day.
x 9720
x 4127
D-Eagle wrote: Wed Jun 07, 2023 4:44 pm I've mostly only been on this forum, so only heard of Ivan's flash on FJR's. This past weekend I was in Canada on a ride. Talking with some guy riding a Kawasaki Vulcan 1700 and he says he had to get it flashed by some guy....and paused. I said "Ivan?", and he said yeah that's the guy. Said it ran a ton better after getting that done. Night and day.
If you check out Ivan's website, he lists all the bikes he has flashes for.
x 48432
x 20501
7 minutes from my front door.
x 9720
x 4127
wheatonFJR wrote: Wed Jun 07, 2023 5:58 pm 7 minutes from my front door.
Or ride over and ask him. Your call.
Spininprop
FJRModel: 2022ES
Sold 2000 Bandit 600
x 972
x 833
Post by Spininprop »
I hear it only on decel where I am next to hard scape like in a tunnel, stone wall, etc. Stock cans. I kind of like it.
Running yosh slipon race cans on my gsxr1000 bikes, decel popping pissed more drivers off than a high speed flyby. 2013 sounded fantastic.
