Aftermarket brake and clutch levers
- x 48396
- x 20486
Re: Aftermarket brake and clutch levers
I bought a set from thetwowheels. They caused clutch slippage. Luckily, I was able get them removed and relocated to a trash can before any lasting damage occurred. I got what I paid for, I suppose.
- x 3518
- x 12940
I have heard bad things about the twowheels ones... would not order from there.
- x 2385
- x 14699
Follow up to add pictures.
Adjusted for shortest reach to lever.
adjusted for longest reach to lever.
I did not have a stock lever to compare to, so added tape measure - end set at center of pivot point.
- x 4463
- x 12609
Wayne, so those are "short" levers? Or standard length?
- x 48396
- x 20486
Those have be short. They look like they would fit my tiny trump-sized hands.
- x 3518
- x 12940
I also believe those are the shorts..... just measured the longs... 7" from pivot bolt to eye.... OEM are same 7".
- x 2385
- x 14699
Shorts.Festus wrote:Wayne, so those are "short" levers? Or standard length?
This cheapo set is at least 8+ years. You can see the color fade, but they are functionally sound.
