Cooling problem
- FjrVfr
- FJRModel: 2012
- x 53
- x 622
Re: Cooling problem
If you mean those two inside bolts that also hold the fans - you're not kidding! My hand is still scratched up from just trying to reach in there and feel them. God only knows how you get a socket or a wrench in there.
I'm going to run it for a while and keep my fingers crossed.
"Anything that happens before or after is just waiting."
- BikerGeek
- x 5348
- x 4705
Re: Cooling problem
My FJR has been running warm for a few years now. I really noticed it when we were in Colorado for NAFO in 2016. It was hotter'n hell that trip. The fans come on when they should and it hasn't overheated or anything, but I've noticed that, especially in traffic, it's been running warmer than it used to.
Last fall, I pulled the radiator cap just kinda wondering if my dirty ol' whore '04 was perhaps burning a little coolant. The radiator was completely full.
My suspicion is that my radiator is gunked up with 130,000 miles of grime. At some point I plan on trying to (lightly) scrub the radiator fins (and, for the record, that'll be the cleanest spot on my bike!) similar to what you did, Mark, but ultimately my plan is to either:
1. Replace the radiator at fall Tech Day. Maybe.
B. Get a newer, lower-mileage FJR. Maybe.
- x 3430
- x 12680
Re: Cooling problem
Pretty sure you'll need the side fairings off. To complicate matters you have to fight the plastic heat deflector (air guide) that is retained by those same two bolts...... shown on Frame diagram.FjrVfr wrote: ↑Wed Apr 14, 2021 1:46 pm If you mean those two inside bolts that also hold the fans - you're not kidding! My hand is still scratched up from just trying to reach in there and feel them. God only knows how you get a socket or a wrench in there.
- x 47
- x 566
- FjrVfr
- FJRModel: 2012
- x 53
- x 622
Re: Cooling problem
I changed the radiator this weekend. Here are some comments and results.
The result? Sweetness! I took it on the same test ride as when I swapped out the thermostat. About 60 miles along the river with occasional stop signs, a few lights and lots of 2nd/3rd/4th gear time. It ran four bars nearly the whole way - I'd say 1 or 2 bars less than the last time and the ambient temperature was about 25 degrees higher (mid to high 80's). All is finally well in the cooling department.
As an aside, this was also the first truly hot day that I got to try my Klim Marrakesh jacket & pants (Alex @ BHM). Thumbs up there too. It's gonna be a hot one this summer and I'm as ready as I can be.
Andy - if you want to have a go at yours sometime let me know. It'll be an "R" rated affair (strong language) but I'm sure we can get it done.
Old:
New:
The void:
Great Ceasar's Ghost Allan, you are a master of understatement. That right side bolt took me a couple of hours to figure out. I'm certain my neighbors think I'm either a convicted felon or an ex-Navy Chief based on the foul language coming from my garage. In the end I used my Jeep's scissor jack to help line things up. I highly recommend a second set of hands for this job. If I have to do that again, I'm selling the bike.
Old:
New:
The void:
BikerGeek loved this
- x 2356
- x 14504
Re: Cooling problem
Good deal - glad to hear that the radiator swap cured the issue.
- x 47234
- x 20070
Re: Cooling problem
You may want to find a recommended local radiator shop and have the old one refurbished, it'd be worth something.
I took my radiator to a shop that my trusted motorcycle dealer recommended. They fixed the hole, cleaned the outside, cleaned the inside, flow tested it then painted it making it look new. $40, next day pickup.
I think I ended up using a bottle jack to lift the radiator into place because it is small and fits tight spaces . Over a lot of years I have collected a large amount of tools, so I can usually find some combination to get even very difficult jobs done. It's like a game for me to figure it out. Clever or not, I usually find some way to bleed when doing any job in spite of wearing gloves.
HotRodZilla and Bounce loved this
- x 47234
- x 20070
Re: Cooling problem
Re: Cooling problem
That's what I wear when giving employee reviews.
What I prefer to wear for mechanics use is unlined deerskin gloves. They are soft and supple enough that I still have very good fingertip feel. A representative picture of what I actually purchase from a local Agway.
In addition to the deerskin gloves I have been gifted with several different pair of mechanics gloves. I kill the mechanics gloves quickly.
- FjrVfr
- FJRModel: 2012
- x 53
- x 622
Re: Cooling problem
I assume so. Light doesn't pass through the old one as well as the new but it doesn't look horrible. No idea what's on the inside. My guess would be that it's some combination of clogged passages inside and out.
- FjrVfr
- FJRModel: 2012
- x 53
- x 622
Re: Cooling problem
I may try that though I don't know of a good radiator shop offhand. I know what you mean about bleeding. Mine had just about healed from doing the thermostat/cleaning. Now I have to start all over again.
- BikerGeek
- x 5348
- x 4705
Re: Cooling problem
PM sent.
