Dark Side Advice Needed
x 48404
x 20490
Re: Dark Side Advice Needed
raYzerman wrote: Thu Jun 04, 2020 1:29 pm Option if you want..... cut down your existing one..... you won't need the original even if you take the CT off... but, some Canadian dick has a spare one in his stash if ya talk nice one day.
That sounds like there is kissing involved. If so, that's right up NTX' alley so he should be in good shape. :stickpoke:
Bust loved this
I got the toe of my boot that's good at kissing, c'mon over buddy... :lol:
Coolio, I might have to talk nice about you for a few days not just one, and maybe get your lunch too for that offer. Thanks Ray
x 9714
x 4127
And Brodie came through with the answer. He's the man! Well, he's the man when Ray's not around.
So I finished up the install today along with speed bleeders and a much needed system flush of front, back, and clutch, including the abs flush. It was really quite simple once I got into it, many thanks to Ray for making the abs flush test harness, and to Wayne and Co. for making them available to us forum jokers.
The shake down run revealed that it's going to take some time to get used to this tire but it's not as awkward as I half expected it to be. It feels to me a bit wallowy at first lean going into a turn but once in it the tire seemed to grip just fine. I won't be trying to keep up with Oface or Jwilly anytime soon, not that I would try to anyway, but I can definitely see the shine that the dark siders like about these. I'm going to enjoy the 30K+ mileage they give. It only took .25 oz to balance which surprised me, I've had some mc tires take as much as 2.5 oz.
Check out the girth on that baby. I measured around 1.25" at widest point from the 180 mc tire to this 205 ct.
I copied Brodie's image when milling mine out
Not a whole lot of clearance up there, but it's enough
Brodie, gixxerjasen, Bust and 1 others loved this
x 12948
You can experiment with pressures, lower will allow greater flexibility, not sure how stiff your sidewall is. I ran 28-30 psi and found that was the sweet spot. You can run it up to 35 or more and see how stiffer it gets, along with different turn-in. So, your next rear tire is in like 50k miles!
NTXFJR loved this
x 47
x 566
Post by Canadian FJR »
After the first ride it will seem like the new normal.
rbentnail and NTXFJR loved this
natehawk750
x 2179
x 2474
Post by natehawk750 »
I like to run mine at about 28psi. I can't even feel the difference anymore.
Brodie and NTXFJR loved this
#69272
I set mine at 31 to start. I may try 28 just to see, thanks for the tips. I will be checking the tread wear as time goes on. The tire should wear decently since it will be carrying quite a bit less weight than a car would have, but that's a double edged sword because that flat profile needs to shed water in a deluge and less weight is an enemy in this case. I don't think I'll be pushing the tire to it's wear bars because of this, decent sipes are your friend.
Mess around with the pressure some. I like mine up around 33. I've noticed with FOBO tpms the rear heats quickly and the pressure rises about 4 psi on a sunny 85*F+ day so be sure to base decisions on miles, not cold pressure.
I have a spare rim I keep a bike tire on, picked it up cheap. Rarely use it anymore.
NTXFJR loved this
x 12948
It will mostly depend on the tire being used. If overinflated the center will wear more, and it may anyway. CT's usually have softer compounds than bike tires, but larger tread depth and wear spread over a much larger area.
Sipes are built for a car’s weight. Don’t know now, but you were a lot lighter than that a few years ago at SFO. 8-)
Uncle Hud wrote: Mon Jun 08, 2020 1:09 pm Sipes are built for a car’s weight. Don’t know now, but you were a lot lighter than that a few years ago at SFO. 8-)
No so much now...
Went to 28 psi and this BFG GForce tire seems a bit easier to lean over. Still getting used to things but it seems quite manageable.
natehawk750 loved this
natehawk750
x 2179
x 2474
You'll get use to it the more you ride with it. I love the Darkside for LDriding when I'm just burning tires on the hwy. I'm not so sold on that I'd ride with it when I'm riding with the intent to carve up the twisties. I'll swap back to a pr5gt for that.
NTXFJR loved this
#69272
x 48404
x 20490
NTXFJR wrote: Tue Jun 09, 2020 11:46 pm Went to 28 psi and this BFG GForce tire seems a bit easier to lean over. Still getting used to things but it seems quite manageable.
Arkansas baby!
NTXFJR loved this
rbentnail wrote: Mon Jun 08, 2020 6:37 am Mess around with the pressure some. I like mine up around 33. I've noticed with FOBO tpms the rear heats quickly and the pressure rises about 4 psi on a sunny 85*F+ day so be sure to base decisions on miles, not cold pressure.
I put tpms on when the bike was new and was surprised at the rise in pressure as the tires heat up. 42 psi is easily replaced with 48 psi on hot pavement, 104f temps in Arizona 3 yrs ago made things really interesting on the back tire especially. I'll keep an eye on this ct next week to see what it does.
x 6276
x 10350
I'm quite surprised you aren't dead yet. I was told that going darkside would make the bike spontaneously burst into flames within the first few miles. Surely I haven't been misled.
natehawk750
x 2179
x 2474
:threadjack:
gixxerjasen wrote: Wed Jun 10, 2020 3:02 pm
I'm doomed I've been running darkside with and Aux tank for a few months now!
gixxerjasen and NTXFJR loved this
#69272
x 6276
x 10350
natehawk750 wrote: Wed Jun 10, 2020 3:36 pm :threadjack:
:shock: :o
