Front ABS Random activation.
- FJRModel: 2008
- x 3890
- x 6046
Re: Front ABS Random activation.
Apparently it was loos enough to convince the system the front wheel was slipping. I tightened everything down, used a couple zip ties and everything worked fine. Stopped at a hardware store picked up a bolt and all is good now.
bungie4, raYzerman, Hppants and 3 others loved this
- mcatrophy
- FJRModel: 2018 FJR1300AS
- x 60
- x 664
Possibly the brake calliper gripping, moving round with the rotor, then grabbing would be my guess. Might not even have been the ABS, just the intermittent movement of the callipers giving a similar feel.
My web site
- Pterodactyl
- x 734
- x 6952
I identified the problem immediately upon being told about the issue at the Lolo gas stop, but I recognized that I had a teachable moment on my hands. So, I let Oface solve the riddle himself. I'm just that kind of giving guy.... you are welcome.
Madmudder, 0face, and wheatonFJR loved this
- x 3523
- x 12948
Glad you got to him first.... I was just gonna text him a FYM.Pterodactyl wrote: ↑Thu Sep 05, 2019 5:54 pm I identified the problem immediately upon being told about the issue at the Lolo gas stop, but I recognized that I had a teachable moment on my hands. So, I let Oface solve the riddle himself. I'm just that kind of giving guy.... you are welcome.
bigjohnsd, Pterodactyl, and 0face loved this
Great that it is sorted out and you didn't ruin your trip (or your bike or yourself). I'm just OCD enough to check bolts three times and then go back out to the bike an hour later to make sure I remembered everything. (Except for the times I forget.) Valve checks make me nervous!
Better be careful about what you report. If you can gixxerjasen your forks, perhaps you can now 0face your brakes?
(I don't think this is a sufficiently epic fail to start using your handle as a verb to describe a maintenance process gone wrong.)
- x 48404
- x 20490
Oh, I think he "0Faced" his brakes alright!FJRoss wrote: ↑Fri Sep 06, 2019 7:07 am Great that it is sorted out and you didn't ruin your trip (or your bike or yourself). I'm just OCD enough to check bolts three times and then go back out to the bike an hour later to make sure I remembered everything. (Except for the times I forget.) Valve checks make me nervous!
Better be careful about what you report. If you can gixxerjasen your forks, perhaps you can now 0face your brakes?![]()
My clutch was engaging unevenly, sometimes badly. Then I remembered I was engaging it with my forearm. Once I got the cast off and switched to using my index and middle finger, it got a little better.
- x 48404
- x 20490
Apparently the middle finger is crucial...bill lumberg wrote: ↑Fri Sep 06, 2019 10:53 am My clutch was engaging unevenly, sometimes badly. Then I remembered I was engaging it with my forearm. Once I got the cast off and switched to using my index and middle finger, it got a little better.
So, was the problem with the FJR or is he keeping a secret...
"Chennai-based motorcycle maker Royal Enfield has announced a recall for 7000 units of the Bullet range of motorcycles. The recall affects the Royal Enfield Bullet and Electra 350 and 500 variants that were manufactured between March 20 and April 30 this year. The recall is related to an issue of a faulty brake caliper bolt that failed to meet the required torque quality to standards, according to Royal Enfield and the recall is a proactive measure given the importance of the part concerned."
- Intech
- x 1466
- x 3562
We will call the OFace recall!!
and..FYM!
and..FYM!
FJRoss wrote: ↑Fri Sep 06, 2019 7:17 pm So, was the problem with the FJR or is he keeping a secret...
Madmudder loved this
