Update-fixed...I hope I don't, but I might have a malfunctioning ABS block
x 47256
x 20078
Re: I hope I don't, but I might have a malfunctioning ABS block
griff wrote: Fri Aug 09, 2019 10:48 pm Mark - I found the right page in the manual Image
Well, like usual, I've already fucked up some of the steps.
x 2356
x 14507
Re: RE: Re: I hope I don't, but I might have a malfunctioning ABS block
1911 wrote:Bring the bike and the book down to the farm in the morning and we’ll see if we can figure out what you overeducated engineer types have fubarred
Now that post is gold, pure gold...
x 47256
x 20078
:D
x 3980
x 6902
Looks like you have a ride to let Duane have a look. Win - win!
chazglenn3
FJRModel: 2008 FJR1300A
x 65
x 32
Post by chazglenn3 »
Speaking of ABS, I just installed Ray's switch the other day and ran the test. Since the rear pulsed twice and the front pulsed once I'm assuming that means all is well?
x 12276
x 9112
gixxerjasen wrote: Fri Aug 09, 2019 10:18 pm
wheatonFJR wrote: Fri Aug 09, 2019 9:00 pm This is where I just step back and blame jwilly. I mean, is it possible he just ABSed the hell out of this thing running from authorities on the way here????
You think JWilly used the brakes at all?
He typically uses ditches, cars, or deer to stop/slow!
x 6005
x 10134
Cav47 wrote: Sat Aug 10, 2019 11:14 am
I miss the like button.
x 3431
x 12686
Wheatie, apologies, I fat fingered something and my little post I did real early yesterday seems to have evaporated.........
If you could not activate the ABS test with a jumper or my harness or whatever.... and if you could not get ABS to work on your back wheel.... and if the ABS light is not flashing..... damned good chance the fuse is blown..... it's hiding as that green 30 amp thing (there's two of them, one is a spare) on the starter relay. It carries the power to the ABS pump (there's a relay involved also). Basically, when you turn the ignition on, the ABS system is energized ready for action.
As for the code 25, it is possible sensor got wet or there is corrosion particles bridging between the aluminum housing (hole) and the steel part of the sensor. There is a plastic sleeve around the sensor that fits in that hole. Clean 'er up, a little dielectric or silicone grease (or almost any grease) to prevent further corrosion. The code just says, I didn't get regular wheel pulse signals... it may be stored, and not showing up anywhere if it is not active (i.e., condition corrected itself). Can be an intermittent thing.
As to why an ABS fuse would blow, ya got me there. If you swap in a new one and it blows, let us know. I have not heard of any blowing, so it would be unusual. If you replace the fuse, re-run the ABS test, see whazzup.
PS - go into DiAG, note all the codes, clear them, see if they come back.
The Gen III have a fancy feature, the ABS light comes on when the engine is started and stays on until the motorcycle rolls a few feet forward. Is this happening?
x 47256
x 20078
ionbeam wrote: Sat Aug 10, 2019 3:09 pm The Gen III have a fancy feature, the ABS light comes on when the engine is started and stays on until the motorcycle rolls a few feet forward. Is this happening?
The ABS is coming on and staying on when started. Then going off after it has traveled a ways. No ABS light has flashed during this episode yesterday or today indicating an issue.
I have some time now...Will be going out to the garage to check fuses now. Unless Alan's logic is that it isn't a fuse, as the beginning diagnostic is powered by that same fuse???
x 1420
x 3456
Ray and I changed out an ABS module on a Gen II. It is a pain getting the air bled out of it. I hope you saved the stock bleeders as it is impossible to bleed the ABS block with speed bleeders. Thankfully I had my old ones. We swapped them out and everything bled. Just throwing that out there if you have to change the ABS module.
x 4139
x 4636
Too many likes...
x 47256
x 20078
So...fuses are fine, none blown.
Going to clean up the sensors next chance I have, which is next Friday. SQ Dance tonight to a rock n roll band, Roan Mountain tomorrow with Duane...
wheatonFJR wrote: Sat Aug 10, 2019 5:05 pm So...fuses are fine, none blown.
And check the connectors for corrosion.
Typically the sensors don't go bad. If the sensor got stuck in the ABS housing (which the Gen III is more susceptible) they can be damaged when chiseling/bashing them out. Connectors are a weak point. There are no connectors but one between the wheels and the ABS computer.
Unless someone used antifreeze and water to flush the brake circuit I can't imagine that the metering block has gone bad on an '013.
x 47256
x 20078
ionbeam wrote: Sat Aug 10, 2019 5:19 pm
Thanks Alan.
x 3431
x 12686
Have not heard of any ABS failures for Gen3's. If ABS light on, good, you can run ABS test again, clean sensors, clear codes, etc. ..... Wheel sensors are waterproof connectors, both go into the ABS ECU. You shouldn't have to go there I wouldn't think.... we'll wait to hear from ya.
x 15258
x 14137
^^^^ like - I highly doubt this is anything serious.
blind squirrel
FJRModel: 2014
x 1536
x 2582
Post by blind squirrel »
ionbeam wrote: Sat Aug 10, 2019 5:19 pm Unless someone used antifreeze and water to flush the brake circuit I can't imagine that the metering block has gone bad on an '013.
I can see a 5-6 year old bike that has not had the fluid changed and the ABS not periodically cycled having a frozen ABS block, regardless of the generation of the bike.
x 15258
x 14137
Just glanced through the "ABS chapter" in my field service manual. The diagnostic part of that chapter is very good. Once you clear the codes and run diagnostics, you should be able to get to the heart of the matter.
