In situ greasing..
x 47355
x 20106
Re: In situ greasing..
I'm just surprised Bust hasn't chimed in. :o
x 3433
x 12705
It is amusing the conceptions and approach some people use.... that guy in the video really needed to do something like a wheel chock to keep the bike from that precarious position. So then he lifts the bike and proceeds to undo the bolts... WTF? Given they can sometimes be a struggle, all should have been loosened before he picked up the bike and not risk the bike swinging around.
There's another video where a guy lifted the bike by the rear seat latch... and another who followed that video and ended up breaking the casting. Always lift with two points, not one. Reduce weight if you like, remove the back wheel.
He mentions the "brown wax" in the bearings, had to clean it out and then found the needles all fell out. It's actually a brown plastic retainer for the needles, need to leave that alone so the needles don't fall out. Take care, it is fragile, especially if older and neglected.
And a hint for those who just want to grease just the rear three while on centerstand. If you remove the rear dogbone bolt and the shock bolt, the relay arm pivots forward so you can easily get tools on the middle relay bolt (the forward end of the dogbones).
PhilJet09, Canadian FJR, CollingsBob and 1 others loved this
x 15298
x 14200
I did this another way - I never did like the idea of "hanging" the bike. Mostly, I don't want to be underneath the 600 pound machine, pushing and prodding on it while swinging, and when it comes unhooked, .... splat.
Take the mufflers off. Take the rear wheel off. Stick the rear axle back in the swingarm/pumpkin. Jack up on the axle. Set the rear peg sets on your jack stands (I have since built boxes to raise the jack stands, as well as a front wheel chock to stabilize it). You can do this on the ground with no problem.
MUCHO safer and stable.
Steel_Gin and LKLD loved this
x 12279
x 9206
^^^^ Whose shop is that in? I see a damn BMW key on the pegboard.
The concept of getting underneath the bike while "hanging" it in any form goes against my better judgement. We know safety man is never gonna do that.
Even on the lift, sometimes I still feel hesitant to lift it up high and start reaching my hands through to clean up the undercarrage. Yeah, even when strapped down, it does shift some. That listing side to side always freaks me out.
x 2911
x 3106
Cav47 wrote: Mon May 02, 2022 2:19 pm ^^^^ Whose shop is that in? I see a damn BMW key on the pegboard.
Ha. Good catch Josh!
x 47
x 566
Post by Canadian FJR »
Pants,
That is exactly the way I do mine for full lubing. I just need to replace the bones on Gypsy’s bike so I’ll try removing the bottom shock bolt and swing the relay aren’t past the Center stand to gain access yo the bottom dog bone bolt.
x 15298
x 14200
That was at a friend of mine's shop, and yes, the Bavarian Sirens got hold of him a LONG time ago. (currently has and RT 1250 and an R1250R).
But as previously stated, you can do this on the ground, no problem.
x 47355
x 20106
Canadian FJR wrote: Mon May 02, 2022 3:53 pm Pants,
Gypsy!
Tell Jude that some nutcase named Wheaton says "Hi"!
PhilJet09 loved this
x 47
x 566
Lol
He’s even more handsome today.
I have to show him this picture when I see him on Wednesday
Steel_Gin
FJRModel: 2012 FJR1300A
x 1425
x 446
Post by Steel_Gin »
Hppants wrote: Mon May 02, 2022 1:24 pm I did this another way - I never did like the idea of "hanging" the bike. Mostly, I don't want to be underneath the 600 pound machine, pushing and prodding on it while swinging, and when it comes unhooked, .... splat.
I would really like to service my relay arm but doing it safely has put this on hold until then. Seeing this setup looks like a great way to go, even looks better than lifting it from above which I don't have anything solid enough, I think, in my garage to make it happen. Maybe I can pull this off in the fall. Thank you posting that picture!! Now getting access to a lift like that for a week or so.
x 15298
x 14200
Again, you don't need the lift. You can do this from the ground (slab) of the workspace. The lift makes it a bit more convenient, but it is not necessary.
Steel_Gin
x 1425
x 446
Post by Steel_Gin »
Hppants wrote: Tue May 03, 2022 1:08 pm Again, you don't need the lift. You can do this from the ground (slab) of the workspace. The lift makes it a bit more convenient, but it is not necessary.
Agreed. Having the lift to lock in the front wheel is my first choice, being easier to work on is a great bonus. If I can't get access to one plan B is to run straps from the handlebars to the Canyon Cages.
PhilJet09
FJRModel: 2009 FJR1300A
x 3154
x 1342
Post by PhilJet09 »
https://imagizer.imageshack.com/img903/5005/ZMce8Y.jpg
If you take enough of the heavy stuff off, it’s a lot less dangerous. :D
I got these rear sliders a long time ago and they’ve been most useful for crap like this. Take the exhaust off and you can lube everything back there very easily, plus do a thorough cleaning.
Steel_Gin and wheatonFJR loved this
Calm is a skill.
