Adding zerk grease fitings to Relay Arm
Re: Adding zerk grease fitings to Relay Arm
@ Enxss
Snowflake/Russ doesn't visit this sandbox often, click his Forum name and send him a PM. He is a neighbor and riding friend, if you can't reach him post here and I'll send him PM.
- Snowflake
- FJRModel: 2014ES
- x 6
- x 92
Hi Enxss, I don't have one for sale at the moment. But I can turn yours around fairly quickly, if you send it to me for rebuild. If you believe the bushings, sleeves and seals are in good shape, turnaround is about 3 days. If you need new parts, well thats a different story.
I will PM you my contact info.
- Snowflake
- FJRModel: 2014ES
- x 6
- x 92
- FJRModel: 2005 FJR1300
Hello Russ, do you have any of these already modified for sale? Then I can ship you mine once I have a modified one?Snowflake wrote: ↑Tue Mar 26, 2019 1:28 pm Tom, We all get to decide what level of risk to take on regarding bike maintenance. For me it is worth it to do this mod for the piece of mind of having these bearings serviced regularly. I do it every spring when I do the rear brake lever pivot (also a zerk), the shift lever, the clutch lever and front brake lever. I've rebuilt enough FJR relay arms to know that the inner sleeves can get trashed. I have no record of the maintenance on those trashed ones.
Pants,
First question, yes. Although I think I drilled the 3/32 'passageway' hole first, then drilled and tapped the zerk fitting hole. The bearing race slots are put in with a .025" thick grinding wheel, not a drill.
I'll try to explain the DogBone sleeve greasing a little better:
The cavity in the relay arm for the two dog bone sleeve bearings is slightly bigger than the sleeve. The hole I drill for the zerk fitting goes into the middle part of the relay arm between the two bearings. There is only one zerk fitting for the middle bearings. I make no modifications to the middle bearings.
To grease the middle bearings, first push the inner sleeve to one side about 1/16" inboard of the bearing seal. Then pump grease into the zerk until you see grease coming out around outside of the sleeve and inside of the bearing seal. The entire inside of the bearing just got new grease. Then push the inner sleeve back through that just greased seal to expose the seal on the other end. Repeat the pumping to fill that bearing with grease. Push the inner sleeve back flush with the relay arm faces. That entire volume around the inner sleeve should be full of grease now.
Hope that makes sense. It may sound complicated, but it isn't. Greasing the two middle bearings takes about 1 minute after you get the dog bones off.
Russ
Thank you
David
Hello sir, I tried to send snowflake a pm about this mod to see if he had one available, but when I went to his profile it didn't allow me to send him a message
Thank you
David
- x 48425
- x 20491
David, I believe you need 3-5 more posts to be allowed to send a message. Not sure of the exact number. Something about keeping bots from spamming everybody's Inboxes.
KYFeeJeR, I forwarded your message to Russ 9/27/20 @ 8:45 am.
- x 6
- x 11
@Snowflake,
I am wondering if you still offer this service of adding zerk fittings to the relay arm?
Thanks,
Stan in Minnesota
Thanks,
Stan in Minnesota
2014A - My first FJR!
Previous bikes: '73 Honda CB175, '75 Honda CB360T, '72 BMW R75/5, '83 BMW R80RT, '97 BMW K1100LT
- FJRModel: 2013 FJR 1300A
- x 23
- x 6
- Bust
- x 6167
- x 1767
Complete directions are in the 1st post guys, it's not that hard to do if you have simple tools an ain't a half wit like Wheaton or Geek
wheatonFJR, Cav47, CollingsBob and 2 others loved this
- x 4054
- x 6947
Wheatness got promoted from full wit?
CollingsBob, wheatonFJR, and Bust loved this
- FJRModel: 2015 A
I see Snowflake has not been on since December 2021. Does anyone know if he still offers this service and how to get in touch with him?
- Snowflake
- FJRModel: 2014ES
- x 6
- x 92
There are a couple Zerk modified model A relay arms for sale in the other sandbox. FYI
I am still desperately hoping for one for an ES.
- x 12958
Hey, just send Russ a message, and if you can find a used one, I'll bet he'll fix one up for ya.
I have one for sale…it’s attached to a nicely farkled ‘17 ES..
Hppants, FJRPittsburgh, and bill lumberg loved this
