ES fork and shock rebuilds
x 48437
x 20503
Re: ES fork and shock rebuilds
El Toro Joe wrote: Tue Dec 04, 2018 4:29 pm ...and your attempt at German is lame :lol:
...so korrect him on his ugly Deutsch schreiben.
A true Deutsche Person would do that. :stickpoke:
x 48437
x 20503
Prestone wrote: Tue Dec 04, 2018 5:09 pm My ES shock failed, and Yamaha Yes covered to the tune of almost 4k.
Was it leaking oil or just plain unrideable due to miles?
Bugnatr
x 7153
x 7082
Post by Bugnatr »
Holy bumpy ride Batman, I thought my Wing shock was pricey at 1,500.
BTW thanks mother Honda for covering it under the ext. warranty.
Prestone
x 182
x 137
Post by Prestone »
wheatonFJR wrote: Tue Dec 04, 2018 5:11 pm
Leaking oil. I wish the high miles was the case. Had about 36k when it failed.
x 48437
x 20503
Too bad the dealer did not send the leaky shock to an aftermarket shock refurbisher...
griff
x 266
x 756
Post by griff »
Ha, talked to the BMW guru that John referred to. He is not aware of any ES replacement for the FJR shock, just suggested good aftermarket replacements. Hell, for around $2k I could a superior suspension set up for my red headed bitch, just not ES. Sumpin to think about. We did discuss what happens when I disconnect the ES wiring, does the FJR go into fits and not run right, or does it just say my suspension is hosed. Anyone with an ES have suspension malfunctions that affected the overall bike performance? Or is it time to drink the kool aid and get an ES bike that is serviceable :lol:
Prestone
x 182
x 137
Post by Prestone »
wheatonFJR wrote: Tue Dec 04, 2018 5:49 pm Too bad the dealer did not send the leaky shock to an aftermarket shock refurbisher...
That was the plan if I were to get it back. I would also send it to Griff if he wants it. That way his working shock doesn't have to be the test dummy.
x 15868
x 14999
Considering the contents of this thread, I'm kind of glad I went with the "A' model. I really (REALLY) like the bike and kind of thinking that I'm going to ride this one to 100K or more. When it's time, the rear shock problem will be a $500.00-ish problem. Not a $3,000.00 problem.
jwilly and bungie4 loved this
x 48437
x 20503
Hppants wrote: Tue Dec 04, 2018 6:56 pm Considering the contents of this thread, I'm kind of glad I went with the "A' model. I really (REALLY) like the bike and kind of thinking that I'm going to ride this one to 100K or more. When it's time, the rear shock problem will be a $500.00-ish problem. Not a $3,000.00 problem.
I hear ya...but the point of this thread is to see if the collective of smart people on this board is to see a way through to something far less expensive.
I may never get an ES, but I would love for my buddy griff to still rack up those monster BMR points on a replacement ES shock for much less...and others as well. Including Bugnatr, when he comes back to the fold.
x 3894
x 6046
wheatonFJR wrote: Tue Dec 04, 2018 7:14 pm
HA! Did you hear that griff? Wheaton thinks he's your buddy...
El Toro Joe, jwilly, bungie4 and 2 others loved this
Bugnatr
x 7153
x 7082
Post by Bugnatr »
wheatonFJR wrote: Tue Dec 04, 2018 7:14 pm Bugnatr, when he comes back to the fold.
I ain't fold'n nutin for nobody.
x 4055
x 6948
bungie4 wrote: Tue Dec 04, 2018 4:12 pm Why would you think it would last 115K when 'normal' FJR shocks are showing signs of being baffed in as little as 20K.
True. 😂
Just because the shock isn't leaking or the spring hasn't collapsed doesn't mean it's still serviceable. When you had your leaking shock swapped for a new one you didn't notice the difference?
philharmonic
FJRModel: 07 FJR1300
x 169
x 172
Post by philharmonic »
I think I need to raise the price of my 400 dollar Ebay ES shock to 1200 dollars. LOL
Prestone
x 182
x 137
Post by Prestone »
bungie4 wrote: Tue Dec 04, 2018 9:32 pm
True. 😂
Not really. It was leaking from the resivoir, and not the actual shock. I think I caught it pretty early on.
https://1drv.ms/f/s!AnJmVgSGGBwjnHeFnk3jTHgUnpzL
x 12312
x 11269
Prestone wrote: Tue Dec 04, 2018 6:51 pm
The rules may have changed, but when I was a Yamaha dealer we had to retain parts replaced under YES for 180 days, they are subject to recall by MAMAYAMA. Once past 180 days we were supposed to dispose of the parts.
Prestone could check with his dealer to see if the shock was recalled by Yamaha, if not it would likely be available for retrieval and future experimentation by one of the aforementioned gurus.
Prestone
x 182
x 137
Post by Prestone »
bigjohnsd wrote: Wed Dec 05, 2018 12:09 am
I called today asking for it back and they said they would get back to me. Fingers crossed, but not real hopeful
bigjohnsd and Hppants loved this
I've heard of 2 or 3 ES shock leaks, and they were the preload adjuster not the actual shock...... probably an o-ring and re-fill the adjuster like we did in the old days on GL's and ST's..... but since "The Book" don't have no serviceable part numbers, just replace the entire shock. Similar to replacing the entire throttle body on a Gen3 if the TPS goes... idjits.
If I had an ES, I'd stick with OEM system and not disable it. Or trade it for a superior A model. :stickpoke:
If refurbing an ES shock, take the opportunity to re-spring it for your weight.
bungie4 loved this
griff
x 266
x 756
Post by griff »
raYzerman wrote: Wed Dec 05, 2018 3:00 am If refurbing an ES shock, take the opportunity to re-spring it for your weight.
That's what I would do for sure, since I weigh a dainty 250 :D
x 4055
x 6948
griff wrote: Wed Dec 05, 2018 8:14 am
Sounds like retirement is agreeing with you! I must be getting close, I'm knocking on 200.
x 15868
x 14999
Two-fiddy? Dang, man! That South Carolinian fried chicken is pretty darn good, no?
My '14A is gonna cross 50K either this weekend or the next. Now that I think about it, the rear shock ain't what it used to be. I'm not opposed to the upgrade, it's taking the entire back end of the bike apart that's worrisome.
