Slow start: Help me figure this one out...
- x 3432
- x 12686
Re: Slow start: Help me figure this one out...
I'd do the easy stuff first, connections clean and snug, battery charged, start in neutral. If at rest voltage (overnight) is dropping too much (e.g., ~12.5 volts), then there's a parasitic draw or the battery is suspect. If you hook up a voltmeter and crank it, voltage should not drop below say 11 volts. If it does, take the battery and have it load tested.
Starter draw will be up to 80 amps while cranking, if much more than that, starter is suspect. Could be the relay too, but I doubt it at this point.
Let us know what you find......
Bust loved this
- FJRModel: 2008
- x 3766
- x 5927
Battery sits at 12.6V when I turn the key on it goes to 12.2-12.3. When I hit the starter it droops to 9.5....raYzerman wrote: ↑Tue Oct 17, 2017 1:26 pm I'd do the easy stuff first, connections clean and snug, battery charged, start in neutral. If at rest voltage (overnight) is dropping too much (e.g., ~12.5 volts), then there's a parasitic draw or the battery is suspect. If you hook up a voltmeter and crank it, voltage should not drop below say 11 volts. If it does, take the battery and have it load tested.
- silverback
- x 1250
Re: RE: Re: Slow start: Help me figure this one out...
That's a pretty square indication it is bad. Next step is a proper load test, which means take it out and charge it fully. Take it to an O'Reilly's or Autozone and have them check it. It will most likey show bad.0face wrote:Battery sits at 12.6V when I turn the key on it goes to 12.2-12.3. When I hit the starter it droops to 9.5....raYzerman wrote: ↑Tue Oct 17, 2017 1:26 pm I'd do the easy stuff first, connections clean and snug, battery charged, start in neutral. If at rest voltage (overnight) is dropping too much (e.g., ~12.5 volts), then there's a parasitic draw or the battery is suspect. If you hook up a voltmeter and crank it, voltage should not drop below say 11 volts. If it does, take the battery and have it load tested.
Then time to hit up warranty. You could just skip to this step. I have never seen a battery that tanks under starting load pass a load test.
FWIW, batteries are sometimes bad from the start. It happens, and sucks.
- NTXFJR
- FJRModel: 2016 FJR1300A
- x 2900
- x 1527
True, batteries can be and sometimes are bad when still new, but I don't think even a properly functioning battery that can pass a normal load test can maintain acceptable starting voltages when faced with a hard short to ground.
Fwiw, sounds like it may be: a) less likely, cable between starter relay and starter motor is shorting out to the chassis somewhere, (look for brunt arcing spots or damaged insulation), or b) more likely, the starter motor armature is shorting out.
Like was said, getting OReilly's to run a load test on the battery might be an easy item to eliminate. If you have a clamp on amp meter or access to one, you might also try that. Ray mentioned 80 amps which sounds about right for a starter under cranking load for our bikes. In the other sand box, somebody measured 175 amps no load bench test on their bad unit, and 40 amps no load bench test on their replacement unit.
Bust loved this
- FJRModel: 2008
- x 3766
- x 5927
I'm leaning towards B.NTXFJR wrote: ↑Tue Oct 17, 2017 6:38 pm True, batteries can be and sometimes are bad when still new, but I don't think even a properly functioning battery that can pass a normal load test can maintain acceptable starting voltages when faced with a hard short to ground.
- Bust
- x 6167
- x 1767
fontanaman, NTXFJR, and wheatonFJR loved this
- FJRModel: 2008
- x 3766
- x 5927
Yeah... I’m going with the starter...
El Toro Joe, Bust, and wheatonFJR loved this
- Bust
- x 6167
- x 1767
That's what happens when you neglect changing your starter oil.....
clocklaw, Uncle Hud, and NTXFJR loved this
- FJRModel: 2008
- x 3766
- x 5927
- x 47264
- x 20080
If Bust sends you a link...DON'T click on it, jes sayin.
clocklaw loved this
- FJRModel: 2008
- x 3766
- x 5927
Major Pain in the Balls to get the starter out. took a bunch of pics and will post a DIY when I can. Freakin throttle bodies have to come out... however you don't have to completely disassemble them to get them out, I was able to move them out of the way.
clocklaw loved this
- NTXFJR
- x 2900
- x 1527
Shite,
Clean that thing up and get another 100k out of it.....
raYzerman and Uncle Hud loved this
- yamafitter
- FJRModel: 06AE retired. 21 Triumph Rally Pro 900 / 16 Yamaha WR450F
- Location: Outside of Toronto therefore off the edge of the world.
- x 76
- x 703
You can use the synthetic blinker fluid. Stops the flux capacitor from sticking.
Bust and NTXFJR loved this
- x 10729
- x 4133
Yeah...that doesn't look quite right
- x 3432
- x 12686
It doesn't really look all that bad, the grooves in the commutator aren't filled up, however the oily stuff could degrade performance a bit. Clean it up to get rid of the oily stuff, make sure the brushes are moving freely, clean up the comm, put it back together.........
The battery readings are concerning...... get that checked out.
0face and NTXFJR loved this
- silverback
- x 1250
It works on your bajaj too. Just sayin'!
El Toro Joe, 0face, Bust and 2 others loved this
- NTXFJR
- x 2900
- x 1527
Just a thought, you might consider also replacing your starter relay while you're in there. The treated contact tip surfaces are designed for a normal amp load, they will overheat and degrade rapidly when under high amp loads.
Bust loved this
- Bust
- x 6167
- x 1767
Umm, Don't you have staff that can do this for you Mr Mayor?
You can't advance your political aspirations without a good scandal.
clocklaw, 0face, and NTXFJR loved this
- FJRModel: 2008
- x 3766
- x 5927
I'll have to use campaign funds to pay them or maybe just have the Russians do it.... Hmmm... that reminds me, I have to delete some emails.
Hppants, Bust, and El Toro Joe loved this
- x 47264
- x 20080
I love how you pretend this little sexual problem you have is somehow related to a bike's starter motor.
Even providing pictures and such...impressive con.
Bust loved this
