- x 12959
IMHO, you can use vac or pressure bleeders all you want (not 100% reliable in my experience, the vacuum ones anyway), but in the end, you need to finish off with a conventional squirt.... and Speed Bleeders do not allow backflow of air or fluid from your bleed hose. The threads are sealed and there's a spring-loaded ball in the bottom..... However, the system must be full of fluid ahead of time, as that ball valve needs to see some fluid pressure to work. I love SpeedBleeders, nothing better IMHO.
wgharper, D-Eagle, SkooterG and 2 others loved this
- x 4520
- x 2296
So what if it sucks air around the bleeder threads? This air doesn't get in the system. And if you really don't like it put a dab of grease around the threads. Thick grease is not going to be sucked in and will block entrance of air.Toter wrote: ↑Wed Aug 13, 2025 9:47 am I have one of these, but find it difficult because it seems to pull air in through the threads of the bleeder. They are great for replacing fluid, as they can quickly suck out the old fluid from the MC without a mess, as well as pull fluid through quickly. They are especially nice for doing an auto or truck, where there is a lot of fluid to move.
wgharper loved this
- x 4520
- x 2296
Am too lazy right now to download the manual from HF but IIRC the bleeder wants 65 or 100 PSI. If your pancake compressor can sustain those pressures then all is fine. I doubt it, the bleeder requires a large amount of air.
wgharper loved this
- x 2442
- x 3278
I've done that, but still gotten a steady stream of air. It's not a big deal, I use it when replacing fluid. Even though bubbles are showing, I know it's bled due to the amount of fluid moved through.N4HHE wrote: ↑Wed Aug 13, 2025 8:27 pmSo what if it sucks air around the bleeder threads? This air doesn't get in the system. And if you really don't like it put a dab of grease around the threads. Thick grease is not going to be sucked in and will block entrance of air.Toter wrote: ↑Wed Aug 13, 2025 9:47 am I have one of these, but find it difficult because it seems to pull air in through the threads of the bleeder. They are great for replacing fluid, as they can quickly suck out the old fluid from the MC without a mess, as well as pull fluid through quickly. They are especially nice for doing an auto or truck, where there is a lot of fluid to move.
- x 15868
- x 14992
400 km today on the FJR under sunny skies and 72-ish degrees. Absolutely perfect weather.
Ride report forthcoming.
Stay thirsty, my friends.....
Niehart loved this
- natehawk750
- x 2179
- x 2474
El Toro Joe, Bugnatr, Niehart and 4 others loved this
#69272
#69272
- wgharper
- FJRModel: 2007 FJR1300A
- x 110
- x 114
Got my oil and filter swapped yesterday and bent my shift lever back to the correct location (bent by a large rock on the Dalton Highway last month). Putting the bike away for 4 weeks while we head up to our cottage in Ontario for some late season fun, but at least the bike is now fully serviced post-AK and ready for EOM next month!
FJRMaverick, fontanaman, Hppants and 5 others loved this
- x 1716
- x 2627
I rode my '23 FJR today. What a POS! After 44 days and 8,000 miles of riding one of my '09 FJRs all across Europe with it's Ohlins shock, Racetech fork springs and valving, simple throttle lock and bonding with that FJR after basically living on it for 6 weeks............
I got on my '23 FJR with POS car tire, crappy ES suspension, and complicated electronic cruise control and I was like ACK!!! What is wrong with this POS???? In 6 weeks all '23 FJR muscle memory was gone....
I am slowly adjusting back.........
Niehart, Spininprop, fontanaman and 3 others loved this
- x 48437
- x 20501
Yep. Aftermarket suspension and a motorcycle tire on back is the sweet spot. But go ahead and and adjust to the car tire...cuz that's you.SkooterG wrote: ↑Mon Aug 18, 2025 3:30 pm I rode my '23 FJR today. What a POS! After 44 days and 8,000 miles of riding one of my '09 FJRs all across Europe with it's Ohlins shock, Racetech fork springs and valving, simple throttle lock and bonding with that FJR after basically living on it for 6 weeks............
I got on my '23 FJR with POS car tire, crappy ES suspension, and complicated electronic cruise control and I was like ACK!!! What is wrong with this POS???? In 6 weeks all '23 FJR muscle memory was gone....![]()
Seriously jealous of your trip...twas epic. Go ahead, order that large ice cream cone.
- FJRModel: 2014-A
- x 291
- x 284
And go looking for some local cows!!wheatonFJR wrote: ↑Mon Aug 18, 2025 3:42 pmYep. Aftermarket suspension and a motorcycle tire on back is the sweet spot. But go ahead and and adjust to the car tire...cuz that's you.SkooterG wrote: ↑Mon Aug 18, 2025 3:30 pm I rode my '23 FJR today. What a POS! After 44 days and 8,000 miles of riding one of my '09 FJRs all across Europe with it's Ohlins shock, Racetech fork springs and valving, simple throttle lock and bonding with that FJR after basically living on it for 6 weeks............
dan
Bugnatr, raYzerman, SkooterG and 2 others loved this
- x 1716
- x 2627
If I have any influence at all over that fat bastard Claus there will be nothing but coal for you this Christmas!!!Dan Cooper wrote: ↑Mon Aug 18, 2025 3:48 pmAnd go looking for some local cows!!wheatonFJR wrote: ↑Mon Aug 18, 2025 3:42 pmYep. Aftermarket suspension and a motorcycle tire on back is the sweet spot. But go ahead and and adjust to the car tire...cuz that's you.SkooterG wrote: ↑Mon Aug 18, 2025 3:30 pm I rode my '23 FJR today. What a POS! After 44 days and 8,000 miles of riding one of my '09 FJRs all across Europe with it's Ohlins shock, Racetech fork springs and valving, simple throttle lock and bonding with that FJR after basically living on it for 6 weeks............
Seriously jealous of your trip...twas epic. Go ahead, order that large ice cream cone.![]()
dan
Dan Cooper loved this
- x 2442
- x 3278
So, sell that POS and set up one from old stock. Such first world problems!SkooterG wrote: ↑Mon Aug 18, 2025 3:30 pm I rode my '23 FJR today. What a POS! After 44 days and 8,000 miles of riding one of my '09 FJRs all across Europe with it's Ohlins shock, Racetech fork springs and valving, simple throttle lock and bonding with that FJR after basically living on it for 6 weeks............
- x 5057
- x 6799
Hey SkooterG if you need a 17 ES POS drop me a PM!
- x 1716
- x 2627
- x 1716
- x 2627
'I already got one. You want a matching twin?
- x 12312
- x 11267
Would you take $2500 apiece?
- x 5057
- x 6799
I may have a use for the 17 ES. My wife came home a couple of day ago and said we need to buy a snowbird home in the Phoenix area in a 55+ community to enjoy the socialization opportunities. I was shocked. We talked about these over the years and she always said no. We agreed to try out this lifestyle choice by renting in Surprise AZ for 3 months this winter. If we end up with a second home the FJR will have a new home.
bigjohnsd, SkooterG, Hppants and 1 others loved this
- x 48437
- x 20501
No need to buy, just move in with 0face.fontanaman wrote: ↑Tue Aug 19, 2025 11:41 pmI may have a use for the 17 ES. My wife came home a couple of day ago and said we need to buy a snowbird home in the Phoenix area in a 55+ community to enjoy the socialization opportunities. I was shocked. We talked about these over the years and she always said no. We agreed to try out this lifestyle choice by renting in Surprise AZ for 3 months this winter. If we end up with a second home the FJR will have a new home.
Bugnatr and SkooterG loved this
- x 12959
Or just park it at Skooter's or borrow one of his........
wheatonFJR, fontanaman, and SkooterG loved this
- x 48437
- x 20501
What? Are you crazy? It will take half the day to locate and remove the boogers from his bike. Plus, he uses those flat bottomed tires cuz he likes how they handle lol. Consider yourself forewarned!
fontanaman and SkooterG loved this
