Amazon.Hppants wrote: ↑Fri Apr 04, 2025 10:00 amwhich vendor did you use?fontanaman wrote: ↑Fri Apr 04, 2025 12:00 am Bought a set of Dunlop Roadsmart 4 for the FJR today for $372 before sales tax.
- x 4675
- x 6295
Hppants and El Toro Joe loved this
- Road Runner
- x 2378
- x 1127
Rode it to work today for the first time this year after redoing the suspension. All's I can say is weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee. I love this bike.
FJRPittsburgh, El Toro Joe, BkerChuck and 5 others loved this
- x 10784
- x 4153
Ordered on Friday, delivered todayfontanaman wrote: ↑Fri Apr 04, 2025 10:44 amAmazon.Hppants wrote: ↑Fri Apr 04, 2025 10:00 amwhich vendor did you use?fontanaman wrote: ↑Fri Apr 04, 2025 12:00 am Bought a set of Dunlop Roadsmart 4 for the FJR today for $372 before sales tax.
- x 2364
- x 14537
Rode it. 2nd ride of the year; chilly temps in the lower 40's this afternoon.
Niehart, El Toro Joe, fontanaman and 3 others loved this
- x 47473
- x 20146
Hey! That looks like Ohio!extrememarine wrote: ↑Sun Apr 06, 2025 4:47 pm Rode it. 2nd ride of the year; chilly temps in the lower 40's this afternoon.
Hppants, fontanaman, and El Toro Joe loved this
- x 6152
- x 10115
Shoot, lower 40's for the high today down here too!extrememarine wrote: ↑Sun Apr 06, 2025 4:47 pm Rode it. 2nd ride of the year; chilly temps in the lower 40's this afternoon.
extrememarine loved this
- x 4675
- x 6295
Mounted a new Michelin PR 4 GT today. Tomorrow I will do some cleaning up and lube the splines then reassembly everything.
BkerChuck, wheatonFJR, and N4HHE loved this
- x 4675
- x 6295
I cleaned and waxed the drive shaft housing as well as the swing arm. Wax might keep tar from sticking a bit. Cleaned the splines and re-greased. It all went well until I measure the tire's air pressure and found it dropped a bit overnight. I checked the valve stem for tightness and inflated it to 42 psi. Being optimistic I decided to reinstall the tire and check the tire pressure tomorrow. Fingers crossed.
Somewhere on the forum I read putting a half inch piece of plywood beneath the center stand helps with tire removal. It worked great as it a bit more clearance pulling the tire out is helpful.
Hppants, N4HHE, and Road Runner loved this
- Road Runner
- x 2378
- x 1127
I clean and grease my shaft every time it in in my hands. JSNS.fontanaman wrote: ↑Mon Apr 07, 2025 6:18 pm I cleaned and waxed the drive shaft housing as well as the swing arm. Wax might keep tar from sticking a bit. Cleaned the splines and re-greased. It all went well until I measure the tire's air pressure and found it dropped a bit overnight. I checked the valve stem for tightness and inflated it to 42 psi. Being optimistic I decided to reinstall the tire and check the tire pressure tomorrow. Fingers crossed.
FJRPittsburgh and D-Eagle loved this
- x 47473
- x 20146
- x 4675
- x 6295
I thought about using the phrase, "Wax my pumpkin." but the word wax was sufficient.
- x 4675
- x 6295
This morning I checked the tire pressure and it was down about one pound from yesterday. TirePressure.org has a calculator for pressure drop using temperature difference. The drops I was seeing was very close to what the calculator estimated.
I am optimistic this is a non problem. Maybe tomorrow I can get out for a ride. Maybe find a Starbucks, might be a short ride!
FJRPittsburgh, N4HHE, El Toro Joe and 1 others loved this
- x 6152
- x 10115
Tire pressure and tread depth are both highly overrated.
- x 47473
- x 20146
PV=nRTfontanaman wrote: ↑Tue Apr 08, 2025 11:52 am This morning I checked the tire pressure and it was down about one pound from yesterday. TirePressure.org has a calculator for pressure drop using temperature difference. The drops I was seeing was very close to what the calculator estimated.
https://www.google.com/search?q=pv%3Dnr ... gws-wiz-hp
escapefjrtist, SkooterG, fontanaman and 1 others loved this
- x 2214
- x 2999
Present value = number of revolutions of rear tire??? WTF?? How about 1 psi change for each 10° F temp change +/-. Good rule of
Freakin engineers!
Freakin engineers!
FJRPittsburgh, BkerChuck, and SkooterG loved this
- x 4007
- x 6911
I got photo voltaics (solar panels) equal n times radians * Time. With n being the intensity.
In a weird way, this is actually in the ball park.
Freakin engineers.
Freakin engineers.
- x 9567
- x 4080
Madmudder taught me something. I have about a 1" high or so lip at the entrance to my garage. I put the FJR on the center stand on top of that lip and it lets the tire hang over an inch higher for easy tire changing. That Madmudder is OK no matter what his friends tell you.fontanaman wrote: ↑Mon Apr 07, 2025 6:18 pm I cleaned and waxed the drive shaft housing as well as the swing arm. Wax might keep tar from sticking a bit. Cleaned the splines and re-greased. It all went well until I measure the tire's air pressure and found it dropped a bit overnight. I checked the valve stem for tightness and inflated it to 42 psi. Being optimistic I decided to reinstall the tire and check the tire pressure tomorrow. Fingers crossed.
fontanaman, gixxerjasen, Cav47 and 1 others loved this
- x 4407
- x 2264
Like this?FJRPittsburgh wrote: ↑Wed Apr 09, 2025 8:22 am Madmudder taught me something. I have about a 1" high or so lip at the entrance to my garage. I put the FJR on the center stand on top of that lip and it lets the tire hang over an inch higher for easy tire changing. That Madmudder is OK no matter what his friends tell you.
- x 9567
- x 4080
Exactly.......N4HHE wrote: ↑Wed Apr 09, 2025 8:52 pmLike this?FJRPittsburgh wrote: ↑Wed Apr 09, 2025 8:22 am Madmudder taught me something. I have about a 1" high or so lip at the entrance to my garage. I put the FJR on the center stand on top of that lip and it lets the tire hang over an inch higher for easy tire changing. That Madmudder is OK no matter what his friends tell you.
- x 4407
- x 2264
Trust me, few will be able to put the FJR on centerstand with more than a 3/4" board under the centerstand. The step in my back patio is 3-1/2", a 2x4 when the concrete was poured. I have a set of ramps made of (2) 2x8s on top of each other which was essential to holding the rear wheel on same level as the front and centerstand to get the bike up. Then the ramp was removed.FJRPittsburgh wrote: ↑Thu Apr 10, 2025 7:42 amExactly.......N4HHE wrote: ↑Wed Apr 09, 2025 8:52 pmLike this?FJRPittsburgh wrote: ↑Wed Apr 09, 2025 8:22 am Madmudder taught me something. I have about a 1" high or so lip at the entrance to my garage. I put the FJR on the center stand on top of that lip and it lets the tire hang over an inch higher for easy tire changing. That Madmudder is OK no matter what his friends tell you.
So if you put a board under the centerstand it is probably a good idea to put others under at least one wheel or both.
This is an older picture of a friend's GL1800 in my driveway using the 2x8 ramps to remove it's wheels. Had one under the front, one under the rear, a 3rd crossways under the centerstand. Four ramps were used. Was rather pleased with myself how the four could be laid out to easily roll the motorcycle on to. I think one ramp was used upside down half overlapping another for the front.
