The All Balls are are the Tapered/Timken style. Just did this job on the Super Tenere last winter and it appears just like the S-Ten the pressed race on the stem of the triple clamp will be a bitch! The S-Ten I used my Dremel and a bunch of thin cut off blades to cut one side then hit it with a cold chisel. Suggestion always welcome.Red wrote: ↑Thu Nov 14, 2024 10:14 amPanman,
I believe the ball bearings in the FJR steering head are over-taxed, even with the best quality bearings (Timken, SKF, et c.).
Tapered roller bearings are much better suited to the loads we put on them there. I'd still go with the best available, for that use.
It's the only sure-cure I know for FJR head-shake, long term.
Many threads here to help you with the switch to tapered roller bearings.
Just a thought . . .![]()
- x 80
- x 829
N4HHE and fontanaman loved this
- x 4646
I had a new rear tire put on. The PR4GT I was running was thin in the middle. That tire caught a nail on the way home from the install- so the rear I just replaced ran its’ whole life span with a sticky string. Replaced with an RS4
for science.
Going to see a friend for coffee in the morning. Fresh rubber facilitates. Good to be riding a little longer day than I have in a while.
for science.
gixxerjasen, Hppants, fontanaman and 6 others loved this
- x 3528
- x 12985
To get the race off the steering stem, use an air powered chisel, it will zip right off... Dremel cut to split it even better.
- x 4470
- x 12622
Same. Worked great.
- x 48476
- x 20523
Sold a couple sets of PR4s to an interested buyer. Of course in this chilly weather, he brought his FJR to pick up the 2 sets of tires. The garage floor slab is carrying less load now than it was.
- x 4646
The tires were mere misdirection. I was there to look at the bikes.
- x 48476
- x 20523
I got a class on how you transport 4 motorcycle tires at one time.bill lumberg wrote: ↑Fri Nov 15, 2024 6:58 pm The tires were mere misdirection. I was there to look at the bikes.
Bikes will be on sale early spring. First, Duane's bike and trailer. Once that is sold, I will list the Jwilly Special.
BikerGeek and bill lumberg loved this
- x 7165
- x 7098
Excuse my ignorance, what is the Jwilly special ?wheatonFJR wrote: ↑Fri Nov 15, 2024 8:48 pmI got a class on how you transport 4 motorcycle tires at one time.bill lumberg wrote: ↑Fri Nov 15, 2024 6:58 pm The tires were mere misdirection. I was there to look at the bikes.
- x 4528
- x 2297
An air hammer can remove the lower race cleanly but with much violence.Panman wrote: ↑Thu Nov 14, 2024 9:24 pm The All Balls are are the Tapered/Timken style. Just did this job on the Super Tenere last winter and it appears just like the S-Ten the pressed race on the stem of the triple clamp will be a bitch! The S-Ten I used my Dremel and a bunch of thin cut off blades to cut one side then hit it with a cold chisel. Suggestion always welcome.
- x 4528
- x 2297
- x 4646
Paul Harvey should tell that. There’s history in that bike. Even alleged homages to its’ origins…
Bugnatr wrote: ↑Sat Nov 16, 2024 12:00 amExcuse my ignorance, what is the Jwilly special ?wheatonFJR wrote: ↑Fri Nov 15, 2024 8:48 pmI got a class on how you transport 4 motorcycle tires at one time.bill lumberg wrote: ↑Fri Nov 15, 2024 6:58 pm The tires were mere misdirection. I was there to look at the bikes.
Bugnatr loved this
- x 9738
- x 4127
Ed and I learned this when installing new races and bearings in my Kendon trailer hubs. If we didn't Dremel a slice in the old race, it would get stuck in the hub when using it to press in the new race.
- FjrVfr
- FJRModel: 2012
- x 56
- x 643
I mounted the RS-IVs that finally arrived. Like Mr. Lumberg I have a certain scientific curiosity about them.
After install, buttoning up, and putting tools away I always do a last walk around that includes checking tire rotation. I'd like to thank the sonuvabitch at Dunlop who thought styling the company logo like an arrow was a good idea. Damn near soiled myself.
Bugnatr, FJRPittsburgh, bill lumberg and 5 others loved this
- x 4470
- x 12622
480 miles for Saturday, 39 degrees at wheels up, rode over close to Jim, Warm Springs, Covington, close to White Sulphur Springs, Rt 311 over to Paint Bank, over to Salem on 311, up to Blue Ridge Parkway for 103 miles of the Parkway. I’ve only been on that part of the parkway a couple of times. It was outstanding. Sunrise to sunset. Awesome day of riding, was in the upper 50’s mid day.
If you haven’t ridden the extent of Rt 311, if you are in the area, make time for it. It’s so good.
Bugnatr, Hppants, BikerGeek and 6 others loved this
- x 3528
- x 12985
I love 311. I can imagine it was a great day.
Toter, Festus, bungie4 and 2 others loved this
- x 4646
Swapped on the hydration system and custom seat.
- x 11032
- x 4260
Guess you are planning on going for a little ride...
- x 48476
- x 20523
Topped off the battery yesterday. Thumbed the starter and it easily turned over. Was glad to hear that after 6 months of neglect. Will get some decent gas this weekend and Stabil to fill up the tank.
After Thanksgiving weekend, every day will really be Saturday so I will be able to get after Duane's bike, so that and his trailer, GPSs, misc equipment will be ready for sale in the spring...or earlier if someone is interested in a well-travelled Black Cherry or Black Cherry trailer.
Hppants, bill lumberg, BikerGeek and 1 others loved this
- x 4646
Changed the oil, FD fluid, filter, washed it, and loaded it. Checked in with DanH to refresh my memory on his Red Route One through the bottom half of the Sunshine state.
danh600, Hppants, El Toro Joe and 1 others loved this
- x 48476
- x 20523
Going to Margaritaville?
