Check this thread.out. viewtopic.php?f=20&t=2378&p=33331&hilit=sts+turn#p33331Red wrote: ↑Sun Mar 05, 2017 2:23 amNTXFJR,NTXFJR wrote: ↑Sat Mar 04, 2017 8:09 pmYou are correct in that there are only spade lugs on this thing. Smart Turn includes wire tap connectors that the spades plug into. I had entered this project by thinking I was prepared by getting a connector set so that I could make up a custom harness and just plug and play the thing into the factory harness. No luck, the connector I got was wrong, and against my better judgement, I went ahead and used their wire tap connectors to get the job done. Unfortunately imo, wire cutting was involved. I have a pic of the unit and the location where it's installed. Let me know and I can post it up.
Thanks for that fine response. I have a Gen2 (2008), so I'm not sure a picture would help me, but sure, if you have that. What connector did you want to add your mod-harness into? The one that comes from the turn signal switches? Would the right connector-set have avoided the need to cut the factory wiring? I would want to add a mod-harness to my installation.
- John d
- FJRModel: 2008A
- x 929
- x 647
- silverback
- x 1250
I rode it home!!!!
- x 3528
- x 12982
Aha, a Gen3 guinea pig. Haven't installed mine yet, but I have ridden behind Johnd and DesignFlaw.... they seem to work well. NTXFJR has just saved me some work..... As I understand it, there is a 10-way and 8-way connector, signal wiring is in the 10-way. Question is, are all the necessary wires for the install contained in the 10-way..... if so, next where to buy that connector. Guess we should post up in the proper thread..... will do now.John d wrote: ↑Sun Mar 05, 2017 8:53 amCheck this thread.out. viewtopic.php?f=20&t=2378&p=33331&hilit=sts+turn#p33331Red wrote: ↑Sun Mar 05, 2017 2:23 amNTXFJR,NTXFJR wrote: ↑Sat Mar 04, 2017 8:09 pmYou are correct in that there are only spade lugs on this thing. Smart Turn includes wire tap connectors that the spades plug into. I had entered this project by thinking I was prepared by getting a connector set so that I could make up a custom harness and just plug and play the thing into the factory harness. No luck, the connector I got was wrong, and against my better judgement, I went ahead and used their wire tap connectors to get the job done. Unfortunately imo, wire cutting was involved. I have a pic of the unit and the location where it's installed. Let me know and I can post it up.
- NTXFJR
- FJRModel: 2016 FJR1300A
- x 2900
- x 1527
Yes, the correct matching connector set allows for a no cut install, basically you disconnect the left control pod connector, and insert a pre made custom harness in between. It's the best way to do it imo, and it definitely is possible with the right components. I got caught unprepared with my pants down yesterday.Red wrote: ↑Sun Mar 05, 2017 2:23 amNTXFJR,NTXFJR wrote: ↑Sat Mar 04, 2017 8:09 pmYou are correct in that there are only spade lugs on this thing. Smart Turn includes wire tap connectors that the spades plug into. I had entered this project by thinking I was prepared by getting a connector set so that I could make up a custom harness and just plug and play the thing into the factory harness. No luck, the connector I got was wrong, and against my better judgement, I went ahead and used their wire tap connectors to get the job done. Unfortunately imo, wire cutting was involved. I have a pic of the unit and the location where it's installed. Let me know and I can post it up.
Talk to DesignFlaw (Tim), I'm thinking he has a Gen II also and already knows what connectors to use, I know they are different on a Gen III. Iirc he successfully made his own harness for a plug and play install.
- griff
- x 266
- x 756
Got my Kristas on in time to do a crazy BMR ride with Hud and playinatwork. Lights came in handy in West Virginia last weekend to see the black ice I was about to hit at 4 in the morning.
NTXFJR, Uncle Hud, BkerChuck and 1 others loved this
I rode mine to work. Again.
Since it is supposed to be raining for the second half of the day I carried my rain pants to my office.
Didn't feel like driving the truck because the trailer with the BMW R1150R is hooked to it. There is something wrong with having a motorcycle on a trailer but since it won't run I have no choice.
Hey red! I was thinking- instead of cutting into the factory wiring you could get one of Admore's Plug-N-Play rear lighting harnesses and cut into that instead. https://www.admorelighting.com/product/a-fjr2/ I used one of these for additional rear lighting and it really is as they say- unplug factory connector & plug this in. Easy peasy!Red wrote: ↑Sun Mar 05, 2017 2:23 amThanks for that fine response. I have a Gen2 (2008), so I'm not sure a picture would help me, but sure, if you have that. What connector did you want to add your mod-harness into? The one that comes from the turn signal switches? Would the right connector-set have avoided the need to cut the factory wiring? I would want to add a mod-harness to my installation.
- Red
- FJRModel: 2008 FJR1300ABX
- x 225
- x 1218
rbentnail,rbentnail wrote: ↑Fri Mar 10, 2017 12:08 pmHey red! I was thinking- instead of cutting into the factory wiring you could get one of Admore's Plug-N-Play rear lighting harnesses and cut into that instead. https://www.admorelighting.com/product/a-fjr2/ I used one of these for additional rear lighting and it really is as they say- unplug factory connector & plug this in. Easy peasy!
Thanks. Not sure that Admore connector has enough pins, though. Anyway, too late, I ordered up the right connectors (they were cheap!), and I will build a mod-harness for mine like DesignFlaw did. Definitely the right way to go, no doubt. Check his work:
viewtopic.php?f=20&t=2378&p=33331&hilit=sts+turn#p33332
- silverback
- x 1250
I took off the triple tree and replaced the bracket that holds the bar bolts in which was discarded when the PO put on helibars risers.
Shipped the risers.
Took off the mirror extenders.
Rode it a bit. Smiled a bit.
Shipped the risers.
- thompsonian
- FJRModel: 2015
- x 95
- x 76
I dropped some coin today on an SR357 rack and scored a well used Givi Maxia E52 off the FleaBay. Needs some minor patchwork, but it will serve its functional purpose for now.
- x 11029
- x 4259
You might have been able to get a brand new trunk, and the SR357 rack for nearly the same price, from www.motostorm.itthompsonian wrote: ↑Fri Mar 10, 2017 3:25 pm I dropped some coin today on an SR357 rack and scored a well used Givi Maxia E52 off the FleaBay. Needs some minor patchwork, but it will serve its functional purpose for now.
https://www.motostorm.it/en/search.html ... rrency=USD
https://www.motostorm.it/en/accessories ... 56nnt.html
- x 48476
- x 20518
Beer wagon at the Ramble with that E52!thompsonian wrote: ↑Fri Mar 10, 2017 3:25 pm I dropped some coin today on an SR357 rack and scored a well used Givi Maxia E52 off the FleaBay. Needs some minor patchwork, but it will serve its functional purpose for now.
- thompsonian
- FJRModel: 2015
- x 95
- x 76
I paid 2x as much for the SR357 as I did for the case.....El Toro Joe wrote: ↑Fri Mar 10, 2017 3:38 pmYou might have been able to get a brand new trunk, and the SR357 rack for nearly the same price, from www.motostorm.itthompsonian wrote: ↑Fri Mar 10, 2017 3:25 pm I dropped some coin today on an SR357 rack and scored a well used Givi Maxia E52 off the FleaBay. Needs some minor patchwork, but it will serve its functional purpose for now.
- thompsonian
- FJRModel: 2015
- x 95
- x 76
That's a distinct possibility.....wheatonFJR wrote: ↑Fri Mar 10, 2017 3:43 pmBeer wagon at the Ramble with that E52!thompsonian wrote: ↑Fri Mar 10, 2017 3:25 pm I dropped some coin today on an SR357 rack and scored a well used Givi Maxia E52 off the FleaBay. Needs some minor patchwork, but it will serve its functional purpose for now.
- x 12530
- x 9434
I know this is not necessarily the place for this and no one hates good info after you already sent the money.......but Alex at Realtime Industries or BHMOTO is so good about items like this. And he is a FJR guy. I recently bought a bunch of accessories for my new 15 and his prices and service is the best I could ever hope for.El Toro Joe wrote: ↑Fri Mar 10, 2017 3:38 pmYou might have been able to get a brand new trunk, and the SR357 rack for nearly the same price, from www.motostorm.itthompsonian wrote: ↑Fri Mar 10, 2017 3:25 pm I dropped some coin today on an SR357 rack and scored a well used Givi Maxia E52 off the FleaBay. Needs some minor patchwork, but it will serve its functional purpose for now.
- thompsonian
- FJRModel: 2015
- x 95
- x 76
Live and learn I suppose....no one ever claimed me to be the brightest crayon in the tool shedCav47 wrote: ↑Fri Mar 10, 2017 4:14 pm
- x 12530
- x 9434
Not your fault.......this time. Trust me, I have made some doozies.
That's because you suck. Just sayin'
I have dealt with Alex for several sets of those wonderful reflective decals for the back of the FJR saddlebags. That is IMO the best modification for the money we can do. They cost next to nothing, they weigh nothing, they require no power, they don't detract from the good looks of the bike and they are a NO FAIL safety feature.
- NTXFJR
- x 2900
- x 1527
Put some new shoes under her and wired up a new Garmin 660 in prep for a trip to Charleston, Smokey Mtns, and Harrison. By the looks of it, will likely get a chance to try out the heated gear Santa brought.
- x 11029
- x 4259
Cav47 wrote: ↑Fri Mar 10, 2017 4:14 pmI know this is not necessarily the place for this and no one hates good info after you already sent the money.......but Alex at Realtime Industries or BHMOTO is so good about items like this. And he is a FJR guy. I recently bought a bunch of accessories for my new 15 and his prices and service is the best I could ever hope for.El Toro Joe wrote: ↑Fri Mar 10, 2017 3:38 pmYou might have been able to get a brand new trunk, and the SR357 rack for nearly the same price, from www.motostorm.itthompsonian wrote: ↑Fri Mar 10, 2017 3:25 pm I dropped some coin today on an SR357 rack and scored a well used Givi Maxia E52 off the FleaBay. Needs some minor patchwork, but it will serve its functional purpose for now.
No doubt Alex has some great deals, I got my Klim Badlands Pro jacket from him...he had the best closeout price. I also just got a Givi windshield from him, saved $50 on that. But when it comes to a deal like the pricing from Motostorm.it nobody can come close.
